Threads: 60
0
Does anybody know of a Mac shortcut to get to the desktop while playing MM? Sometimes I'm notified that mail has arrived but I'm not able to read it without suspending and quitting the program and then restarting again after I've checked the mail.
Threads: 869
0
Hi Jackie,
You can toggle between full screen and window mode. Hit the Esc key to pause the program, then hit Command-space bar to go to window mode. You can check your mail or whatever, then go back to MM, hit the Esc key again. That might automatically change you back to full screen. If not, hit Command-space bar again.
Threads: 60
0
Perfect, Semi-Native!! The Esc and Command-Space keys to toggle between full screen and window mode works great. Just what I wanted to know. It will come in handy when I want to check the time as well since there is no other clock in my computer room. Thanks! [smiley=happy.gif]
Threads: 60
0
I couldn't get command + tab to work, Wingy.
Threads: 60
0
I never did get command + tab to work and am not sure why. Looked up that shortcut in Apple's Help and it is Application Switcher. Something must not be set up correctly on this Intel iMac and I haven't changed the default. I'm glad the escape-command-space trick works to shrink the window. I use it often.
Threads: 138
0
On my macbook pro, just command-space works
Threads: 340
0
...maybe it doesn't work because I think it only came out in Mac OS 10.4 and you only have 10.3?? :-?
Threads: 60
0
This Mac has OS 10.4.11, Wingy. My friend got a new iMac a couple months ago and she can shrink Midnight Mansion with just command-space too, Matari. I have to hit Escape first. Anyway, it gets the job done.
