Signs
To you guys this may be a stupid question but I've always been baffled by this...
How do you do signs???
I have resedit, but I don't know what numbers to enter..... :-[
First step: Drag your mansion into ResEdit
Second Step: Press Command + K and type in TEXT (all caps) and press enter.
Third step: Type your message. Memorize the I.D. # and when you click your sign with pink mouse, type the # in.
Fourth Step: To make more messagest, press Command + K inside the TEXT category. To change IDs, press command + I when selecting the message and replace the ID # with a new ID #.  Smile
Thanks Wingy!!! Smile
I have the Resedit not!
Where can I download it?
:o
Just Google for it Smile
Alternative resource editors are Rezilla and Resourcerer.
samskelton wrote: To you guys this may be a stupid question but I've always been baffled by this...
I'm able to change the signs with the original editor, but how do you change them in the Expansion Pack ?
If I type in the text I want, then /every/ sign (of the same size) in the mansion says the same thing. Am I completely missing something ? I'm using Rezilla for editing and Photoshop for PICTs .
thanks
GryphonGirl
You don't need to use an resource editor anymore! In the Mansion builder click the red arrow (for editing) and then click on the sign. You'll get a dialog where you can write your message. Just be sure to delete everything inside that dialog before deleting a sign.
