07-15-2011, 12:10 PM
When Jack entered the room 16691 the music stops and I had the message you can see in the picture
Beta 3 - Nightmare Mansion HARD [Fixed: Beta4]
07-15-2011, 12:45 PM
My fault I'm afraid, Vern. I'll write a quick script that will check all mansions for similar issues.
07-15-2011, 06:38 PM
Thanks Rob. Would it be easy to modify the script to report all room numbers in a mansion where music changes? (i.e. index other than 0.) That would be quite useful. (Bonus: if it also lists what index each room changes the music to.)
For instance: 16690: music index 3 17428: music index 2 and so on.
07-15-2011, 06:41 PM
And maybe do
POSSIBLE ERRORif the music index is higher than the build-in music index list. And ERROR ALERT!!!if it's higher than 100.
07-15-2011, 07:41 PM
093A2D31153A312C3A315F0 wrote: Thanks Rob. Would it be easy to modify the script to report all room numbers in a mansion where music changes? (i.e. index other than 0.) That would be quite useful. (Bonus: if it also lists what index each room changes the music to.) Yes - all of these plus what's in your other post should be very easy to do. I'll probably send you an email about this later on today.
07-16-2011, 08:16 AM
Just an update for the thread. Using a script I found that that was the only room like that. I ran it against all mansions in Beta3 and Beta4. Beta3 showed the one room, and Beta4 didn't (since Vern fixed it). So, that's a relief.
« Next Oldest | Next Newest »
