Version 1.3 of The Dragon's Trap / hard released
The easiest and fastest way to download this update, is by going to the 'important topic' (sticky) on top of this board.
Toybox will definitely explain all the 'minor' changes.
Well, I took aquaMat's remarks into account (now I forgot where they were. I can dig them up if you really want me to):
1) If you recklessly pulled some lever (in the Blue/Green Section) you could end up half-stuck with suicide as the only option*. This is no longer the case. The update was made for TDT Normal too.
2) In TDT Normal, there was a secret chamber in which frantic jumping aroung could result in Jack's falling through walls to his demise. The wall was made fool-proof. Amusingly, it had already been fixed in the Hard version :-?
(And maybe I confused Hard and Normal in Item 2 above. In any case the wall is now airtight - or rather, jacktight.)
*Allowing for a sacrifice might have been a deliberate feature in earlier versions, but I wouldn't do it anymore in a regular mansion (that is, without warning Wink).
