Room 16308 Help
Hello,
I am stuck in room 16308, just after the 6th save...how do I go to the upper level?  or do I go else where? Is this where the mansion ends as it is not finished?
Very intriguing mansion.  Very creative.  Everyone's style is so unique.  I love it.
the mansion is called
catacombs
, probably for a reason Smile hope it helps
Hi Missy,
Even though aquaMat didn't design this section (the designer hasn't been on the boards in ages), think like one of aquaMat's designs. Try everything.
Thank you for the support.....thinking of aquaMats designs did the trick. I feel so foolish, I did that all over the place except there.
hawaii wrote: Thank you for the support.....thinking of aquaMats designs did the trick.  I feel so foolish, I did that all over the place except there.
aquaMat designs = hidden and complicated?
Big Grin
Still Stuck
Hi Lara,
Thank You for asking, but I did find the way out.
I really hate the 7th level with all those [highlight]MINI[/highlight] disappearing steps. I lost all of Jacks 9 lives on them.....until I learned the trick, but that took me so many tires, then Jack got killed towards the end with those darn disappearing steps and hidden whatevers.
I will try again to get past that level.
i am stuck in the same room, plz help me ...i have tried evry jump, up n down and searching for any lever, i jus dont seem to be reaching up level. although i have found the low level hidden ...n hopefully all the secrets down...wat do i do to go up ?
Take a close look att the stone work. Where do you see something different? IT might be the place to find the money.
hi rose, are u pointing the hidden way to go down? below the 2nd candle? thts the way i have already found ...and i have completed the below mansion... i just cant find a way to go towards the right rooms...the way from upper level in that room... i cant find anything i can do ...so sorry for this Sad
Check all the walls for different looking tiles in that section.
Users browsing this thread:
