The Vault
Grayson made a little mansion. Here it is. Enjoy!
.zip   The_Vault.zip (Size: 19.53 KB / Downloads: 2)
Ha! Took me a while, but I finally figured it out.
Thanks, Grayson. Looking forward to your mansion.
Any chance to get some suggestion how to get where the lever is ?
Pipps
OK I figured that out too.
Sweet little room !
I had not too much problems to get to where the lever is, however, I don't seem to find any way whatsoever to get to the exit door !!??!! :'(
(Is that on purpose....or a design mistake ?)  Undecided
Bizarre......
BTW: There's some design error with the green door.... it doesn't open properly (upper half stays closed), plus there are
door traces
in mid-air!
Apparently Grayson has put multiple doors over one another (maybe in different layers ?).....  faults like this can be easily repaired though !
Nice mansion (so far)....   8-)  Smile
aquaMat, there is a way to the exit. Keep exploring!
;D
This was fun! It took a while to find the way out. Not obvious at all!
aquaMat - you use this trick sometimes too!
Mmmh.....  I use this trick too ??
Then I should be able to find it, shouldn't I ?
So I guess I'll try again.....  (Though when I last tried (this morning, before I read this) I again couldn't get to the exit...!  Undecided  :'( )
TOTALLY STUCK!
S. Sad
Stuck where in The Vault?
