Dr Tronic's zoo
I'm currently playing Dr Tronic's Zoo and when I end up in room 15896 I find myself being short of one yellow key. I've only been able to discover five, in the areas below
Help, anyone?
Hi Ollie,
Look closely at your map on the right side of the mansion. Let us know if you need another hint.
Good luck!
I see it... thanx Smile
For some reason, neither HD downloadable versions of this game (hard and normal)
open after the 1st save is made. The pop up message says that the file cannot be
found and the game file should be stored in the custom mansions folder, which
it is, otherwise I could have not played it at all, let alone get to the 1st save.
I have not had this problem with the other HD custom mansions. All the saves
were easily accessible. Obviously there is a glitch somewhere and I just can
figure it out.
Is anyone available to help with this problem?
And the name of the custom mansions folder is
Midnight Mansion HD Custom Mansions
Inside the game folders (like the
Doctor Tronic's Zoo Normal
folder) there are a lot of subfolders?
Are the save files stored in:
~/Library/Application Support/ActionSoft/Midnight Mansion/Saved Games/Player's folder/Name-of-game folder ?
If everything above is correct I am afraid I can't help you.
Missy, try this:
Play one of the games the fastest way (don't care about extra keys) until first save and resave. Where does MM HD want to save the game? It should be the path above in your Library.
4F5F4841412D0 wrote: Missy, try this:
Hi Brell, Thank you for responding, yes, it saves it like it saves all the other custom mansion saves, exactly like the path you described, only it does not open from there.
I get that pop up that says what I stated in the previous post.  Hmm?  This is so
very strange.  I don't have this problem with any of the other HD custom mansions.
I had removed the game several times, then re-downloaded it.  I even closed MM and re-opened it and re-downloaded it. I have no idea what else to do.  Pity bcos I really like this game.
I will try it again and see if it will work today.  If you don't hear from me, it means
that I still can't get the save to work.  I will try to get to the 2nd save this time to
see if that makes a difference.  I will use cheats to extend lives if need be to get
to the 2nd save.  Wish me luck.  Smile
Oh, Merry Christmas and I wish you a Happy New Year!
Here is a pic of the pop up that appears:
I guess I will have to play the game without saving it. Sad
I went thru the mansion 2 more times and of course I had to use cheats bcos
I can't retrieve any saves.  And I get the same pop up as stated in my previous post.
Here are two pics to show that yes, this custom mansion is where it is suppose
to be, yet the system will not let the saves be accessed.
The 2nd pic is where ALL saved mansions go.  See, there are 2 saves for this
mansion and none of them are accessible.
I do not have this problem with any of the other custom mansions, just this one.
.png   Screen_Shot_2014-12-28_at_6_23_12_PM.png (Size: 19.53 KB / Downloads: 1)
The MM HD Custom Mansions folder must be inside the MM HD folder.
Also, the Dr. Tronic Zoo normal folder is one level too deep. You are not supposed to have Dr. Tronic Zoo normal folder inside of another Dr. T.Z. normal folder.
