Help with the Void
Greetings,
Long time but I'm ba-a-a-ck! I enjoy the Void! -Kudos to the author!
I have a couple of questions:
1) Rm. 14698 - some discussion on that switch that's in the middle of the lava, but I still don't get it - how do you walk on lava?; for that matter, how do you get to the other side (enter from the left) of the lava bed (if you're supposed to start from there)?
2) Rm. 14105 - near the end! above the red tower: thanks to the map provided in this room, I see that there's a surprise room above (where all the treasure is), but I'll be darned if I know how to get ther - I've tried everything in this and the adjoining room. Help!
Thanks much, and keep up the good work, you authors!
-DLC
And there is a potential Jack-Stuck in that room (try to find his feet in the picture!). Maybe you should fix it if you release a new version: I don't think it would require a special amendment on its own though.
@ dlcatftwin:
First to your question..... BTW, how do your pronounce your
name
Room 14698:
Walking on lava
is a novel gimmick....and in fact is not really possible (=not for long distances) but it is - with a little skill & care - possible for as long as it takes to pull the lever (due to how I constructed this area):
0f course you have to walk from the right (so ignore what's left of the lava).... you have to basically tiptoe over the lava and after every step try if you can already pull the lever (which you should do as soon as possible).
Once you have pulled the lever you need to immediately JUMP back onto safe ground. Walking back is not possible !!
Please try again.....with a little practice you will manage it.
Room 14105:
Please see the discussion in this thread: https://actionsoft.com/forum/showthread.php?tid=700
If the hints given there shouldn't help you, please get back in touch !
Thanks for playing The Void !!
@ Toybox:
Sorry....but I didn't find his feet !!   :-[   8-)
On the top right corner Wink
I sort of tripped and fell from the room above. :-[
Oooh whaat !!?!
That surprises me immensely.... 'cause I remember having had an eye on this spot during testing: I was aware that the wall didn't get up 'til the ceiling and wanted to know whether that could cause problems, but never managed to end there alive (by jumping from various positions above).... so I decided to leave it in (with an added hidden wall in the room directly above it that prevented the only possible (survivable) fall).
So do you happen to remember from where exactly you
fell
there ??  'Cause it can't be the room directly above it....  Undecided
PS:  If possible I will fix it in the next UD, as you suggested....it won't happen too often, I guess.
One important correction:
Apparently there was a little confusion (on my part) what version is on the
official list
and/or what version you probably played, Toybox.
You see, when The Void was first released, I had sent version 1.0.1 to brell immediately after version 1.0 was already released (brell was too fast for me Wink ).... so we decided we put up version 1.0.1 without much fanfare..... (as version 1.0 was out there for only 30 mins or so).
To make matters more complicated, I had made 2 or 3 other minor changes, including the
security wall
mentioned above, a few hours later.....but later I always had the impression the version out there would already have these changes.
Only after your comment (and after I had checked my copy of The Void, where the fall was not possible) did I go to the list myself and downloaded The Void again to see what everyone was playing. It's a version dated Feb. 10; 17:28 h...... and (sorry to report) it does NOT have said security wall.
Sorry about that.....
The good thing about it, the update is already finished for a long time and I have sent it to brell already. It does also feature a lfew other changes, mostly cosmetic though.
Thanks for telling me, Toybox !!
You're most welcome.
And it really felt like Jack tripped - you end up on the ground but can't remember how the deuce you actually did that. Well, if it's fixed it's even better.
As you ight have seen in the other thread, The Void has now been updated (to what I called Version 1.0.4 !
Brell was again super-fast. Thx to him, BTW.
Greetings again! -
Toybox sagely informed:
Room 14105:
Thank you for the post Toybox.
I do believe the link you provided (and the subsequent discussion) was not geraine to my question, as it refers to the room BELOW the one I had trouble with. I am referring to room 14105, which is above the room that others had trouble with (sort of the second story of the red tower). I am right below the treasure room, and I don't know how to get in!
Many thanks for your help, responses, and great castle!
DLC
It was aquaMat actually.
I, um, never noticed the room above :-[ Never look at maps :-[ :-[ :Smile
