Update 1.1 released
A little issue got fixed. Version 1.1 of The Mansion Family - A Wondrous Place is now downloadable.
REALLY REALLY like this mansion, but, while I'm not sure if I got the original or the update, I find a problem in Room 14693 - a wall I can't get through or around or over or under... maybe I'm headed the wrong way? Or maybe I missed something in the rooms before (to the left)???
HELP!
suzanne
Freddy wrote: A little issue got fixed. Version 1.1 of The Mansion Family - A Wondrous Place is now downloadable.
A little issue? Maybe that was the Jack-Stuck I found:
Room #14 893 - you can jump on the column to the right. It has a little edge sticking out on the left side, if you stand on it you can jump above the top to the right of the column, and then you are stuck (you can go to one of those rooms where Jack leaves without the camera following him... you just hear his footsteps... Oooh, creepy!).
Or was it when you go to the first room with 'moving floor' (lots of platforms going up and down - a lovely room, really; didn't pick up the number though). Arriving from the left, after reading a BBB telling you how useful it is to practise jumps (I think), if you just walk innocently you fall down to Jack's death. Like a floor mismatch, but because the platforms are moving (I think if he arrived on a stable platform the fall wouldn't happen.)
Reached the 5th Saving point; I love the mansion so far :o
suztours wrote: REALLY REALLY like this mansion, but, while I'm not sure if I got the original or the update, I find a problem in Room 14693 - a wall I can't get through or around or over or under... maybe I'm headed the wrong way?  Or maybe I missed something in the rooms before (to the left)???
HELP!
suzanne
Hi Suzanne,
thanks for playing TMF3...I'm glad you like it.
As for room #14693....   Just look very hard, try everything and you will find the solution !!  There is no JS situation in 14693 !
I doubt you missed something in the rooms to the left....  you just didn't find the solution yet !
Keep on playing....
Toybox wrote: A little issue? Maybe that was the Jack-Stuck I found:
Toybox.... as usual you go JS-hunting  Big Grin  ;D.  What you have tpo know: In the room you mention (BTW, we shouldn't be talkin' about it....it could spoil it for some people), what is hidden behind the column is a barricade. I had to raise it to PREVENT Jack-stucks. What I don't understand:
1.  Didn't you activate the platforms first ?  (If you did jump onto the hidden barricade, you could always jump back onto the platforms if they come along.
2. I have raised the hidden barricade so a jumping to the area RIGHT of the column cannot result in a JS, as the jump must lead to death. I don't understand how you managed to jump down there and survive ??!
Toybox wrote: Or was it when you go to the first room with 'moving floor' (lots of platforms going up and down - a lovely room, really; didn't pick up the number though). Arriving from the left, after reading a BBB telling you how useful it is to practise jumps (I think), if you just walk innocently you fall down to Jack's death. Like a floor mismatch, but because the platforms are moving (I think if he arrived on a stable platform the fall wouldn't happen.)
Exactly.  And even if the platform is moving it happens only rarely....  The platforms are aligned in a way that most of the time you'll survive. However, the BBB has been put there to warn players that something might happen.....
BTW...we really shouldn't give to many surprises like this away (I'm sure there are enough members out there, who haven't yet played TMF 3) !
Glad you like it, Toybox !
Hidden text here:
PS: In the next update I will re-design 14893 in such a way that it is no longer possible to jump onto the column from the top right.  (Jack is not meant at all to jump there....what you see behind it is just the not-yet actoivated platform, I think)
aquaMat wrote: [quote author=suztours link=1194812716/0#1 date=1194859246]REALLY REALLY like this mansion, but, while I'm not sure if I got the original or the update, I find a problem in Room 14693 - a wall I can't get through or around or over or under... maybe I'm headed the wrong way?  Or maybe I missed something in the rooms before (to the left)???
HELP!
suzanne
Hi Suzanne,
Keep on playing....
AquaMat - okay, so I messed around and messed around and then it hit me what I needed to do in 14693... so after a few stops & starts, suspensions while I thought about it, and such, now I've finally finished my first time all the way through. My results go like this -
Time: 59:38
Score: 22,450
Secrets: 84% (I found 21)
Lives left: 8
Will give Jack a rest while I do some actual work and then give him another go later, probably tomorrow!
Anyway - great mansion! One
negative
comment is that the exit is a bit of an anti-climax. Or maybe I didn't find the real exit yet? I don't know, but if what I found is the exit, maybe you could
dress it up
a bit????? Just a thought.
suzanne
I had activated the platforms (otherwise I don't know if I could have stood where I stood). I'm not sure what is the use of this little corniche I was standing on. In any case what I did afterwards is called, I think, a squirrel jump. :Smile I should try again, really Wink
Suzanne,
I know what you mean.... in this mansion there is not the usual
gold chamber w/ exit room
, instead there is plenty of gold in the last few rooms before the exit.
I had to do it like this, as I wanted to include the little gimmick, that you can already see the exit in one of the first couple of rooms but can't get there until much later.
I loved how you showed us the end at the beginning, it made me want to go exploring!
Thanks Josephine, and everybody else, for the nice comments !
@Toybox:
I have edited the room in question a little, so at least a direct jump from up above (highest floor) to you-know-where is no longer possible. However, I will wait until I have a few other changes / improvements to make, before I'll post an update.
Still don't understand how you managed to survive that squirrel jump though...??!?   :o    Undecided
