Connecting 2nd monitor to G5
Has anybody of you ever connected a 2nd monitor to an Apple PowerMac G5 (pre-Intel; Dual 2 GHz; inkl. ATI Radeon 9600).
I know that it's possible...what I do not know:
- Will there be a limit to screen resolution and / or color resolution after I connected a 2nd moniztor ?
 (At the moment I'm running the main (and only) monitor with 1280 x960 (75 Hz) and 16 Mill. colors. Will I be able to keep that resolution ?)
- I plan to use the 2nd monitor as
enlarged desktop
.  But what will happen, when I switch on my computer and only 1 monitor.... will the Mac
automtaically realise
that I have not switched on the second monitor on this particular day, even if it's connected..... and will it 'adjust' the desktop accordingly ?
- What happens to MM, if I have 2 monitors running ??  Will it be full-screen, but only in the main monitor ?  And what is on the other screen then ?
I'll appreciate any advice, knowing that it's rather off-topic to our usual conversations in this forum.   Smile
aquaMat wrote: - What happens to MM, if I have 2 monitors running ??  Will it be full-screen, but only in the main monitor ?  And what is on the other screen then ?
MM will run on your main screen, and your other screen will go black.
Don't know the answers to your other questions.
I have an idea! How about... like mario cart DS, one screen is the game, the other is the map! :Smile Just a thought.
That's actually a pretty great idea. But I don't think there's enough people playing dual screen MM to make it worth Vern's time.
It would probably get higher rating on sites! Tongue :Smile (Vern needs the extra cash) Wink
So nobody can answer my max.resolution question above ??
Hold down option at startup and press
leave monitor at is current
button. Smile
aquaMat wrote: So nobody can answer my max.resolution question above ??
You should try to ask this question at an Apple/Mac forum Wink
brell wrote: [quote author=aquaMat link=1173192905/0#5 date=1173272304]So nobody can answer my max.resolution question above ??
Yeah, yoiur probably right, brell...... although I thought I save myself the trouble to create an account at some Mac-forum just for that one question....
Can't you just press the
at the startup of MM holding down option? :-?
