Threads: 12
0
Am I missing something? I can't find a freaking purple key to use in the room of many doors. Anyone have a hint? I found three in 16495 but used one is 16696 and 16497. I used one more but didn't write down the room. (Probably 16298) Anyhow, speaking of 16298, there is a bug when I try to go up and get the second red key. When I go up the left ladder, i can't ever get stablized in the brick wall above. Jack can get the red key on the right but, I've only been able to retrieve the left key once. All of the other times I've attempted, Jack just falls down.
*sigh* I have no life!
-Jen
Threads: 2,609
Together with ACO, the House of Wonders is one of the very hard mansions. Because they also contain a master puzzle. And in HoW that puzzle is room 16696, where the problem is, which doors will you open FIRST. That is NOT a matter of luck or trial and error. You need to get through with analysis, deduction and elimination.
To answer your 2 questions.
1° You find 3 purple keys. That is okay. You really don't need a 4th one.
2° I checked your problem in room 16298 and could NOT reproduce it. Both left and right did give me any problem. So that is odd. The ladders end at a floor where it is impossible to fall down ... :-?
Threads: 344
0
I do remember I had a lot of troubles to figure out how to solve this. but that is the beauty of the game because when one manage to solve the problem one is happy for along time and all the swear word are used!!! ;D
I don't remember how I solved it though :'(
Threads: 12
0
It just seems once I get to a new piece, there is no way out. i.e. That crazy lattice ladder room. I can't get to the second platform. to go to the next room. I can get to the bottom and the third one down but, there are steel doors on the other side making it impossible to pass.
I can get to the finish, but I'm no where near 100%! Lots of ladders don't work and I'm wondering if that's supposed to be that way or just another rouse.
Grrrrr!
Threads: 12
0
I've fanagled (is that a word? lol) my way through going a different way but, I have two questions. First, is the down ladder in 16697 not supposed to work either up or down? Second, the lattice-work ladder room, 17297 I think... I can get to the levels with steel doors on the other side but not to the second level where I can switch the lever. Is this correct or am I missing something?
-Jen
Threads: 2,609
I am deeply ashamed. The ladder between # 16697 and # 16897 has no function at all. Any more. It is a very awful remainder of Works in Progress 1.6.3. Really sorry about that. In an ugrade I should surely remove it.
About # 17297. Yes, you are missing something. But it is tough. I know. It is possible to reach ALL floors without leaving this room.
Threads: 12
0
Ok... onward and upward. ;-)
