Less than 1 minute ago
Castle Doom Hard room 16705
by oaktable
Hmmm...I can't seem to get around the zapper beams guarding the green door in room 16705 of Castle Doom Hard. I've got the green key, and I need to get past the door to get the all-important blue key; but the only way I can get past the zappers is when the blocks are in place under the ladder, and of course when those blocks are in pace the blue key is inaccessible. I've tried several times to jump when there is a lull in the two zappers but it never works. I always get fried. Any ideas? Thanks everyone!
Re: Castle Doom Hard room 16705
by Olle the Greatest
I had hard time doing that too the first time[s]You have to jump at the right time. Try again, and watch the zapper beams closely
by Semi-Native
Welcome, oaktable.That is hard. Timing is everything here. Getting back out is even harder.Good luck!
by oaktable
Thank you amigos! As long as I know it can be done I will not despair.
by Toybox
Actually, getting back is easier, because you only need to lose at most one Jack
I never managed that going back jump safely.
by Semi-Native
[quote author=Toybox link=1218556538/0#4 date=1218628216]Actually, getting back is easier, because you only need to lose at most one Jack
I never managed that going back jump safely.[/quote] ;DMe either! So, if you don't mind losing a Jack, I guess it is easier.
wow I thought I sucked at this game
of course, I've tried many times before succeeding...
by oaktable
by Semi-Native
by oaktable
by Toybox
I never managed that going back jump safely.------------------------
by Semi-Native
I never managed that going back jump safely.[/quote] ;DMe either! So, if you don't mind losing a Jack, I guess it is easier.------------------------
