02-17-2007, 04:33 PM
Assuming that there is no (more) doubt about the quality of the custom mansion, here is the step-by-step how I am handling the uploading.
PART A.
1° I go to the topic 'Board IDs' and choose an unused number. In the only post of this topic, I add the new mansion with its number.
2° Now I go to the YaBB Administration Center / Forum Controls / Boards with the Admin-tab. At the bottom I change 3 into 1 (for one mansion) and click on go. Then I complete the window as shown in the models 'Edit boards 1', 'Edit boards 2' and 'Edit boards 3' added below.
PART B.
1° I drag the unzipped mansionfile to my own Custom Mansion folder.
2° I check if the game really starts and play a few rooms to see if everything works neatly.
3° I check if all Preview PICTs were removed.
4° At File / Mansion Options I correct the name of the mansion for the maps. That name MUST be: exactly the same as the mansion name, plus the appendix 1.0. (Reminder: 1=first version and 0=no updates yet. The version-number only changes in cases of enlargements or other very drastical changes.)
5° With COMMAND+I, I see what the size is of the mansionfile.
PART C.
1° Now that the mansion is
2° I drag that file to my desktop and delete the word
3° I make a zipfile from the mansionfile at my desktop. With COMMAND+I, I check the size of this zipfile.
4° I open Terminal at Applications / Utilities and give the command: openssl sha . I may NOT forget the space after sha! I drag the zipfile to the cursor in Terminal and press enter to become the Checksum sha.
PART D.
1° Now I go to the board Custom Mansions Area / CMs Sub-forum and open a random topic and make a copy as a reminder of what I need to do for the new mansion.
2° Then I go one step back and start a new topic. The name for that new topic is the Checksum sha, that I copy from the Terminal.
3° I complete the new topic now and may not forget to add the zipfile from my desktop and to lock the topic.
4° When this topic is posted, I have a look at the http-address on top. It contains a number that I will need later to make the links from the 3 downloadlists. I always copy it somewhere.
PART E.
1° I go to Custom Mansions Area / List of Completed Mansions and start with
2° The list is in alphabetical order, so I go to the right place. Now I make a copy of the one above or below and put that copy where the new mansion needs to be added. Then I change the names of the mansion and the designer AND the link-number (see C4).
3° Under the name of the mansion I add: First release on ...
4° I save the post.
5° I now go as well to
6° Then I go to YaBB Administration Center / Forum Controls / Boards. I click at the right of the board
7° Finally I go to YaBB Administration Center / General Controls / Forum News and click on the tab 'Edit Forum News'. Add the correct announcement at the right place. (And if relevant remove old news.)
PART A.
PART B.
PART C.
finalizedfor release, I go to Finder / File and duplicate the mansionfile.
copyin the name.
PART D.
PART E.
Downloads sorted by mansionname. I open that post and click on modify.
4° I save the post.
Downloads sorted by dateand
Downloads sorted by designerand work in a similar way.
List of Completed Mansionsand at the bottom on
Go. At
DescriptionI change the date of the last change and at the bottom click on
Save.
