Less than 1 minute ago
Custom Music
by Wingy
I'm wondering how to add custom music. Tried what the custom level docs. said but nothing happened.
Can anyone tell me how to do it?Thanks!
Re: Custom Music
by VernJensen
My memory is fuzzy, so I don't know if this will work, but you could try it:Create a file named "Background Music 5.mp3". And if you want more music, name the subsequent files "Background Music 6.mp3" and so on.Then put these files into your Game Data -> Music folder. Then in the editor, select 5 and 6, etc. as the index for your background music. Should work, I think...Downside is there is no way to put this music "in" your custom mansion file. You will have to instruct players to add these music files to Game Data -> Music before playing your custom mansion.-Vern
Re: Custom Music
by aquaMat
Thanks Wingy,for putting this question forward, as I'm facing the same problem at the moment (while I'm working on my new mansion "Discotheque Of Doom" (...as the name implies...this will be definitely a mansion in need of custom music)...!!As I happen to produce music for a living (at least when I'm not playing MM), it might be interesting to really WRITE custom music.Thanks Vern,for the explanation & hints.Too bad it's not possible to do it in a way В without people having to manually put the soundfiles into the game data ... as you can never be sure, wether they will really do it. (I confess: I never play MM with the music ON).
Re: Custom Music
by Freddy
I am sure it works the way Vern explained, since I added a lot of music to mansions in earlier days. For private fun.:'( But!!! The bad news is that you can't launch mansions when you don't have all rights to use that music in your mansion. Are you the composer AND the musician? Please, take care about those things. We don't want to bring Vern and his ActionSoft in troubles, do we?
Re: Custom Music
by Wingy
I was thinking maybe we could, put the music with the mansion when you download it. Therefore, there wouldn't be an annoying ERROR message popping up when you try to launch the mansion.
Re: Custom Music
by aquaMat
@ Freddy:Yes. In my case there should be no problem, as for the music I plan to go along with "Discotheque..." I did write, play & produce it entirely on my own (in my studio).But of course there are legal issues involved, would people want to include music from -say- other artists' records with MM.Better not.....@ Wingy:Very good idea.
Re: Custom Music
by aquaMat
The question of custom music turned up again, in another thread (but I put my comment here...in the 'custom music' thread)
I do habe a very good idea, which needs a bit organizing, but will be worth the effort.I'd like to initiate a sort of 'guideline' for custom music:If any designer who wants to include costum music with his mansions would give his custom music a number higher than ALL musics used before, we could minimise the need to exchange files in the Game Data folder, and maybe end up with just one file, which could remain there.In other words:Say, Wingy was the first one to use custom music, he'd start to number his tracks with the number 5 (as 1-4 are used by the original music).Next, I would create a mansion, and I would number my custom music with digits higher than the ones Wingy used.The end user who downloaded several mansions with custom music, could then easily create ONE Game Data/music file which had ALL music tracks ever needed in it (including the original music), and there would never be the need to permanently change files in the Game Data folder. Or -even better- and easier:Every designer could just update the latest 'official' Game Data/music file with his music, and we'd be up and running.What do you guys think?
Re: Custom Music
by Freddy
The idea sounds good, but are you sure you can go further than music no. 9 ? I think I tried that ages ago and it didn't work.
Is of course several MM-versions ago, so I don't know ...
Re: Custom Music
by Wingy
Maybe you could make second copies of the original music and use their numbers? В :-?
Re: Custom Music
by aquaMat
[quote author=Wingy link=1167346314/0#8 date=1168476178]Maybe you could make second copies of the original music and use their numbers? :-?[/quote]But then, Wingy, my whole idea wouldm't work anymore.The good thing about it was, that even someone who wants to play the original levels etc. with original music, wouldn't have to replace the (latest) Game Data/music file.@Freddy: I didn't know about that.
В But I guess it's well worth a try.... I'll try it later today (I'll just name a track 'music11.mp3').
by Wingy
Can anyone tell me how to do it?Thanks!------------------------
Re: Custom Music
by VernJensen
Re: Custom Music
by aquaMat
Re: Custom Music
by Freddy
I am sure it works the way Vern explained, since I added a lot of music to mansions in earlier days. For private fun.:'( But!!! The bad news is that you can't launch mansions when you don't have all rights to use that music in your mansion. Are you the composer AND the musician? Please, take care about those things. We don't want to bring Vern and his ActionSoft in troubles, do we?------------------------
Re: Custom Music
by Wingy
Re: Custom Music
by aquaMat
Re: Custom Music
by aquaMat
I do habe a very good idea, which needs a bit organizing, but will be worth the effort.I'd like to initiate a sort of 'guideline' for custom music:If any designer who wants to include costum music with his mansions would give his custom music a number higher than ALL musics used before, we could minimise the need to exchange files in the Game Data folder, and maybe end up with just one file, which could remain there.In other words:Say, Wingy was the first one to use custom music, he'd start to number his tracks with the number 5 (as 1-4 are used by the original music).Next, I would create a mansion, and I would number my custom music with digits higher than the ones Wingy used.The end user who downloaded several mansions with custom music, could then easily create ONE Game Data/music file which had ALL music tracks ever needed in it (including the original music), and there would never be the need to permanently change files in the Game Data folder. Or -even better- and easier:Every designer could just update the latest 'official' Game Data/music file with his music, and we'd be up and running.What do you guys think?------------------------
Re: Custom Music
by Freddy
Is of course several MM-versions ago, so I don't know ...------------------------
Re: Custom Music
by Wingy
Re: Custom Music
by aquaMat
