Threads: 1,481
0
Room 16297
The ladderjump is not very obvious, which can lead to a cd.
PS have you changed the transition zone? Because now the silver bricks are on but not the gold bricks. Or am I doing something wrong?
Threads: 2,609
You mean the topladder jump at the left. Where the top of the ladder doesn't reach a floor?
There are changes everywhere in the mansion although only to get things (much) better. However in the transit zone the gold/silver issue did not change.
Threads: 1,481
0
No, Jack has not used his key, but somehow he managed to change gold back to silver. I'll start from the first save (is there only one in the purple area?) and check where this happened, but I will propably not be able to until Friday.
Threads: 1,481
0
Found some spare time and found the culprit!
Room 17100
Let´s say that Jack starts by going down to this room before doing anything elsein the transit area. He goes down to the room below and up again at the ladder furthest to the right. Going that way back, he is forced to trigger a floorbutton that toggles gold to silver blocks.
My guess is that this should NOT matter. Jack should still be able to use his rainbow key anywhere he pleases, wright?
