file not working in HD version
i cannot open this mansion in HD .... i am able to open other mansions ..but this one and creepy cottage is not working...can someone help me ? the error msg says this file cannot be opened. check if it is HD.
Check out if you have downloaded the right version. Mine is working fine.
[postsmovedhere1] 1 [postsmovedhere2] Curious Observatory, A [move by] Semi-Native.
yes rose...i checked it again...downloaded the hd zip files of both the mansions...i dont know why are they not working.. Sad
Hello Pooja Ahuja- welcome! People don't post here as often as they once did, but many still read the forums and play MM  Smile
The fix for these two mansions is simple: unzip the downloaded file, and you will see another zip file. Unzip this second one, and put the resulting folder into the MMHD Custom Mansions folder.
I don't know why some of the mansions were zipped that way, but they will play correctly now. Please post if you have any other questions.
Happy playing!
