Hint for 2nd yellow key in the dungeons
Can anybody help me find the 2nd yellow key in the dungeons in Jacques revenge 1?
Can you give a room number so we know what area you mean? Command + D will show you the room number in the upper left corner of the screen.
Room 16521 is the room where you enter the dungeons. I have gone completely through and reached 2 blue doors and 2 yellow doors. Can't find the second yellow key anywhere.
I think I might know what the problem is. When you were in the palace (before climbing down into the dungeons), did you explore all up above in the palace section and go on the red moving platform maze?
Yes I did, and at the end of the red moving platforms there were 2 keys before the save at the top of the palace. At that point I have 2 blue keys, 1 green key, and 1 yellow key.
Hmmm, I had 2 yellows and 2 blues (I played last night up to the point of entering the dungeons). So the key is somewhere before you reach the dungeons, but I can't remember exactly where.
If I get time, I'll try to play through again so I can help you out. In the meantime, you might want to start over, at least from the last save, to see if you can find it.
OK, I'll keep looking for it, but I've already spent hours trying to find it.
Rickfal, did you go down the ladder (only partially visible) in 16319 and go left to 16316? That triggers a moving platform for you to take up and jump up on a vine. There's a yellow key to be had up there.
Thanks, I'll try it and let you know.
