05-02-2012, 06:46 AM
aquaMat,
Here's a report on the levers that are now
It's a bit of a hassle, but probably an easier solution in the long run (hopefully).
Checking Perpetuum Mobile/
Scanning mansion room sprites...
17493 contains 1 buried lever
18494 contains 1 buried lever
18692 contains 1 buried lever
18693 contains 1 buried lever
18694 contains 1 buried lever
19091 contains 1 buried lever
19291 contains 1 buried lever
19294 contains 1 buried lever
19491 contains 1 buried lever
19689 contains 1 buried lever
19691 contains 2 buried levers
19890 contains 1 buried lever
19893 contains 1 buried lever
20093 contains 1 buried lever
20290 contains 1 buried lever
20291 contains 1 buried lever
20292 contains 1 buried lever
20489 contains 1 buried lever
21090 contains 1 buried lever
21092 contains 3 buried levers
21292 contains 1 buried lever
21294 contains 1 buried lever
brokenin MM HD. The best advice I can give here would be to move the levers back up, and possibly change the graphics to the levers to hide the base. You could do something similar with the green base by making the entire image transparent.
