Chateau de Medusa Normal (beginning area)
by VernJensen
So I was just playing this a little bit just now, testing the upcoming MM 1.1.9, and I think I've run into a place where you can get stuck? What if, when you first start this mansion, you go to the *left* instead of to the right? I find that you end up clearing as much as you can of the lower area, but then are stuck. I find myself on the right side of room 18093, unable to get the yellow key, and seemingly able to progress without it. Am I missing something, or can you actually get stuck in the first part of this mansion, if you start it "in the wrong order" (i.e. by not going to the right at first)?
Re: Chateau de Medusa Normal (beginning area)
by Semi-Native
You're right, Vern. I just tried it and did eventually get stuck.
by brell
Actually you won't get stuck but you will miss the area behind the yellow door if you take the left wing first.I will leave it to you to find out how to move on i.e. not get stuck.
