Stuck at Falcon Manor easy
I am stuck on the blue side of Falcon Manor easy, the room with all of the leavers.
The rooms i am having problems with is 18896,18897,18899 and 18900.
The first screenshot shows where i am stuck. If i activate the leaver in room 18896 then i am unable to move into 18897..The only way to move on is if i jump to my death..Am i doing something wrong?  I don't understand the how all of these blocks and levers work
Hi!
You are going to far to change the blocks. You have a lever closer to use.
Yes, sometimes you have to explore for things which may be hidden, or at least partially hidden.
arrgh, regarding the lever in 18896: You only have to use it IF the silver bricks in 18897 are off. Now go back and pull the lever again to switch from gold to silver bricks.
Remember: The gold/silver bricks levers always switch between gold and silver bricks for the whole mansion.
All this is explained in the game manual.
There's a manual?
I think brell meant the tutorial, which is Hint House in the HD version.
Sorry, I didn't realise that no manual or documentation was released with the HD version. It was included with the original game.
