11-14-2011, 10:47 AM
Room 16903.
Lever is above the plane and isn't usable.
MM HD Deserted Holiday Village: floating lever doesn't function.
11-14-2011, 11:28 AM
Keep going on this, mick. I'm pretty sure something happens to solve that problem, eventually.
11-18-2011, 02:11 AM
One can sincerely hope.
11-21-2011, 11:59 AM
@ mick:
As the designer of this mansion I can assure you that this is not a building flow. So there is reason to go on and not await any repairs. The solution is rather easy. First pull all other levers and the problem will solve itself.
11-21-2011, 12:09 PM
In one of the final rooms of ADHV there are a whole bunch of green doors and snakes and an exit door that I prefer to remove in the HD version. And replace by something else.
Question. Since this is an easy mansion, should I put a saving spot after each house?
11-21-2011, 03:39 PM
Freddy, it will be easier to change the HD version after the HD builder is released (which is not number one priority on Vern's list - yet).
No comment on saving spots.
11-21-2011, 06:04 PM
It is also not a priority on my list. First of all I like to play. A lot. And there is so many new stuff.So yes, I'll wait for the HD builder. |
« Next Oldest | Next Newest »
