A perplexed Portly Senion!!
This 80 yr old needs help with Art's Mind Mansion HD. I have been trying to get that darn green key every witch way I can think of :'( for two days now and have had zilch luck. All I would like is a good hint--please.
Hi Spaz- do you mean the green key in room #1601? (If you don't know, press the
command
and
d
keys, and the room number will appear in the upper left corner.)
For room 1601 you need to enter from the left. Try going up first  Smile
[movedhere] General issues and game bugs [move by] Semi-Native.
Hi Josephine- Thanks for the reply. Yes that is the room. I have gone up the rope and jumped to the right and left but do not seem to be able to go any further to the left to get the key.
After you climb up, there's a hidden lever that will let you go to the left.
A general hint I use when stuck: Jack only has a few actions- climb up/down, jump up/down, pull levers. Try everything, especially when he goes behind a wall  Smile
Oh said the blind man
I SEE I SEE
! Many Dankas for the help! Smile
You're welcome. We've all been in that boat here  ;D
