Faces Hard - noticeboards no text = attached pic
Hi, I am not sure this is the right place to post this, but the HD version of Faces Hard has no text on the boards and so it quits every time one is pressed. Screenshot of one of them attached.
Hi Matari, yes this has been discovered and it's being worked on to solve the problem. This will probably occur in other mansions, so please continue to report them as you discover them.
Thanks!
While this does still need fixing in the mansion file so that the sign is readable, the next release of the game will give you a polite error message (and you can continue playing) instead of quitting when this happens. :-)
You are doing a great job guys!
My fault on this one i'm afraid. There shouldn't be too many like this.  Thanks for reporting it. The problem you're reporting applies to both versions of FACES.
It would be better to post about custom mansions in their own categories but this can also count as a game bug.
