01-27-2007, 07:45 PM
I need help on knight manor - easy. I don't know how to get past the room with the ladders and zappers in it. Help!!!!!!!!
Knight Mansion - easy
01-27-2007, 08:33 PM
Which room exacly are you talking about? Press command + D in game in that room and the number in the upper-left corner is the room number. Tell me that number and I might be able to help!
01-28-2007, 06:10 PM
I think you mean Room 15907? If so, just watch the beams carefully and you should be able to plan your path.
Good luck! 8-)
06-23-2007, 09:30 PM
Arrgh, I am having the same problem, is that room ACTUALLY possible? The first beam you see when you get up flashes off for like a split second but not long enough for Jack to get through!!! Grr... soooo frustrating!!!
06-23-2007, 09:53 PM
IF we are really talking about room 15907, then ... you don't need to cross any zapper beam. Just use the ladders around them to reach the only lever in that room. It is just a small maze. Continuing is easy after pulling that lever.
06-23-2007, 10:51 PM
duh....
06-24-2007, 10:48 AM
It's okay, gadgetguy - just be patient and look at everything
when you enter a room - most mansions (at least the included ones) are puzzles that must be solved as well as rooms to explore - you'll get the hang of it.Enjoy! ;D suzanne |
« Next Oldest | Next Newest »
