07-28-2011, 07:21 AM
IMPORTANT: You'll need to delete your existing saved games, profiles, preferences, etc. I changed settings in beta 5 so you need to start over from scratch with this version. Sorry!
www.actionsoft.com/files/temp/MidnightMansionHDbeta5.zip
Those with international keyboards: please test two things:
1) Do the proper symbols show up in your Options dialog when you change key settings?
2) Can you use - and + keys to zoom in and out on the map screen? (This might not be fixed, but I can't quite tell.)
Version History:
- Disabled
- Fixed spelling in teaser screen for episode 1.
- Fixed bug where game could easily crash when doing Command-Q to quit during the game. (Or in other instances too.)
- Fixed weird backgrouund that would appear if you hit Command-Q while on the in-game map screen.
- Pushing the action key to dismiss a sign in front of the exit door at the end of a mansion no longer causes Jack to exit the door.
- Zapper beams now always show as
- Updates to Tomb of Princes, Hint House, Falcon Manor Normal, and The Great Escape.
- Organ player screen now has HD artwork. Create a new player profile and start a new game to see it.
- Saved games now go in a new subfolder just for that mansion. This is to pave the way for future changes to make saving / opening saved games much more seamless.
- Game now asks
- Your custom mansions folder should now be called
- Please note: clicking/popping in the footsteps or landed sound effects has NOT been fixed. I will work on this in a future beta version, as apparently my entire sound library needs to be replaced with something better.
Version History:
- Disabled
lever jumpexploit for built-in mansions.
onon the map, even if the beam's starting delay isn't 0, as long as the beams actually are on. Please test zapper beams a lot in this beta release, both in the game, and in the map, to be sure they still work properly!
- Game now asks
Are you sure you want to quit?if you click the window's red close button while playing a game.
Midnight Mansion HD Custom Mansions- MIGHT have fixed the issue where - and + keys were not working to zoom the map when international keyboards are used. Can you please test? This might not be fixed still! If not, I'll need some further help with fixing it.
