Beta 2b - Falcon Manor EASY
Room 15902 JS up in the right corner!! if you jump from the right most vine to the right.
version 2b.
I can't find how to correct the first post after it is posted.
Now it works after at un-ticked to view post in reversed order. I didn't know that is was ticked, at least not by me.
Something we did for MM2 testing was have single threads for mansions. You can see some of that in other threads on the board: Tomb of Princes NORMAL is one example. It has all the posts related to issues with Tomb of Princes.
I think it would be a good idea to continue this. It makes it easier to see all the issues associated with a mansion in the fewest number of places, and reduces the number of top-level posts a little so that *most* of what is on top are general-purpose game engine bugs/issues.
Rose, I'm sorry but I'm going to hijack your post and change this topic to Falcon Manor EASY. Please continue to post any other issues you find with Falcon Manor EASY here. I'll also cross-check to make sure the same issue doesn't occur for NORMAL and HARD.
Right! Will do.
There is no room 15902 in Falcon Manor Easy, Normal, or Hard. Nor in various other mansions I tried to open. Rose, can you confirm what mansion, difficulty, and room you're talking about?
Sorry, if I messed things up. It will have to wait as I am of for a week of vacation. Seems it is needed! ;D
[movedhere] MM1 HD tester's board [move by] Rob Seegel.
