Beta 2b - minor glitches [Fixed: Beta3]
After finishing a mansion, and the in-game high scores screen is present, you have to click on
Done
at the top right twice before you exit that screen (it's not highlighted by default).
Sometimes, after a Save, the arrow keys don't work the first time, you have to hit it again.
Just fixed the first issue. (Took a long time! Bug in SDL I had to work around.)
Also, I think the exact same cause of the first issue has caused the second. I've done a change in the code that should fix the second issue if I'm right. Can you please let me know when beta 3 is out if it does? Thanks.
Do note: this will result in the behavior of the game
freezing
when Jack jumps on a save pedestal, and he will remain frozen until you release all keys. This is the only way I can see of fixing the problem.
This might be confusing to some players, but hopefully if they get confused, they'll release the keys, at which point the dialog will appear. Jack does change into the
statue pose
so it's not too confusing I don't think.
I reviewed both issues in Beta2b and Beta3, and it appears to be fixed to me.
Yes - it is a little different that the Pedestal won't save until Jack stops walking, but not *that* different.
Semi-Native: Can you also verify both of these issues are taken care of? I've got a separate test log that I'm going through, trying to ensure every issue is verified and regression tested.
Thanks in advance!
44797445737371737A160 wrote: Semi-Native: Can you also verify both of these issues are taken care of? I've got a separate test log that I'm going through, trying to ensure every issue is verified and regression tested.
Thanks in advance!
Both these issues appear to be fixed, thanks!
