01-17-2007, 09:00 AM
Dear designers. More and more players are using COMMAND+D as a standard during play. That it is pretty logic, because in the first place, one sees in the right lower corner how many secrets has been found so far. Above that, the roomnumbers in the upper left corner are a big help for a good conversation on the boards.
The consequence of the yellow
Before making this post, I asked Vern if it was possible to change these in an easy way. Sadly, it isn't. It seems to be a major work to move these things out of the playing-window. So it is best that the designers, in the first place, take care.
stuffin three of the room-corners, is that playing-hints from the mansion-designers may be covered. I wanted to put everyone's (builders AND players) attention upon that.
