Secrets in Mt. Peril Normal
Has there been a change in the number of secrets from version 1.0.0 to 1.0.1? In the 1.0.1 version, MLB2 says there are 17, but a scan of all the rooms reveals only 16. Or is there a way to have a secret that can't be seen in MLB2? Or am I just a blind old so-and-so?
Seawinder
I have had the same thought. I can't for my life get the 17th secret. >Sad
There are 17 secrets according to my version which is in 1.0.1, so it's there... somewhere. :Smile
Check each section to see if you got them all: (Spoilers)
4 in the 'mine/storage' section (The bottom left section)
1 in the 'elevator shafts' section
3 in the 'sky platform' section - one of which is accessed from the green section.
2 in the 'green fortress' section (The top)
5 in the 'church/dark crypt' section - one of which is accessed from the cave section
2 in the cave section - one of which is actually in the elevator shaft section but accessed from the cave section.
... and that's 17.
Anthony:
In the section you reference in the third line of your list (spoilers), if
one of which is accessed from...
includes room 15098, then I have to say I'm not seeing any secret in that series of rooms. Hm.
Seawinder
The other two are in rooms 15699 and 15899. Tongue
Huh... I don't have a way of checking at the moment, but was this one of the mansions that was fixed in the last update as far as secrets go? Do you have the 1.0.1 version seawinder?
I'm probably wrong, but I thought I'd throw the idea out there.
This was one of the mansions updated, it was only the number of secrets was incorrect that was fixed.
Anthony:
I'm having trouble matching what I'm seeing for secrets with your descriptions. Here are the sixteen rooms where I find secrets (going room by room in the editor):
SPOILER ALERT
15301, 15303, 15502, 15504, 15695, 15699, 15899, 15905, 16101, 16303, 16305, 16306, 16698, 17298, 17300, 17698.
Seawinder
695459685E5E5C5E573B0 wrote: Do you have the 1.0.1 version seawinder?
Yes, I have 1.0.1. In fact I re-downloaded it just to make sure.
Is it possible to have a secret placed so it's hidden in the editor by another object?
Can someone put me out of my misery: check out the list of rooms with secrets in my last post and let me know where the 17th one is, assuming it exists?
TIA
Seawinder
You're missing the secret in 15098. The
S
is behind the painting in that room in the editor and being hidden.
Two notes:
• You can select the blue
S
in the editor and in the special menu and using the
Find Sprite in Mansion
and it will tell you each room.
• You shouldn't use the editor to find secret, the game would lose its shine quickly, and it is (to me at least) essentially cheating, sort of. Asking for hints on the forums is the way to go, which you were doing, so that's good. Tongue
