Jack stuck in Mt. Peril Hard
Forgive me if I'm posting this in the wrong place. I think there's a Jack stuck in Mt. Peril Hard, screenshot attached. I was able to jump from the lower part where the door is, clear the floor, and end up on the red trap door. As far as I can tell there's no way to get out of there.
Thanks, this will be fixed in the next version 1.0.2.
Another possible JS in this mansion is in the same part as the screenshot from spacegorilla. I just played it and opened one of the purple doors in 15301, and the purple in 14903. I also used my green key from 15101 in room 15102. Therefore I could not get the purple key in 14901. Don't know if I missed something though, but I really couldn't see a way out so I had to restart from last save and open both purple in 15301. That worked fine.
That is the same procedure my Jack would have done if he encountered a
cul de sack
796271160 wrote: Another possible JS in this mansion is in the same part as the screenshot from spacegorilla. I just played it and opened one of the purple doors in 15301, and the purple in 14903. I also used my green key from 15101 in room 15102. Therefore I could not get the purple key in 14901. Don't know if I missed something though, but I really couldn't see a way out so I had to restart from last save and open both purple in 15301. That worked fine.
Did you get the purple key in 15100?
yes I did, and used it on one of the mentioned doors...
