map work in Builder?
Does the map function not work in the Builder while testing/playing rooms? I know it did in the original MM, but am not having it work in MM2.
It works for me in MM2.  Smile
That's probably because your name is mapman. ;D
I've attempted with some of the included mansions (Trigger Island, The Caves & the Castle, Blackheart Keep), the beta mansion I'm testing, and one of my creations that I'd started before the release of MM2. I do NOT get the map function to work at all.
That sometimes happens, you'll just need to restart the level builder.
Thanks, that did the trick. Smile That hadn't occurred to me since I tried both of my computers and had the same problem with each.
