Problem with Mt. Peril easy
I have reached room 17700 with the
escape pod
, but it only goes up to the next room above (17500) because of two wooden bricks that are in the way. This means that I cannot get the last yellow key and thus cannot explore all the treasure room.
The room IDs you gave don't exist, and I'm not sure what you're talking about... Sad
7C42454C522B0 wrote: The room IDs you gave don't exist, and I'm not sure what you're talking about... Sad
What are you talking about?  I was playing Mt. Peril easy.  Room number 17700 is the room with the gray
escape pod
.  Jack pulls the lever behind the four red doors to the right and thus gets access to the
pod
at the bottom.  By
pod
I mean the gray bat platform that goes up when Jack steps on it.  The
pod
is supposed to move up to the left side of room number 16500, where Jack gets a  yellow key and pulls a lever to open a grey door in order to get to the treasure rooms.
But the
pod
never gets to room 16500, because in 17500, which is right above room 17700, there are tvo wooden bricks that stop the
pod
.  This means that Jack cannot get that yellow key to the left in room 16500 and thus can't get access to the rooms behind the yellow door in room 16704.
Check rooms number 17700 and 17500 in Mt. Peril easy.  If the
pod
is supposed to go up to room 16500 (as in Mt. Peril normal), then these wooden bricks in room 17500 (between two green disappearing platforms) are in the way.
I have checked the room numbers in the editor.  They DO exist.
Interesting Brell. That's the mansion I've played the most times and I've never had that occur. Could it be a game bug or something?
Are there not two wooden bricks in room 17500 just below the blue key, Catwoman?
Does the grey bat platform go all the way up to room 16500?
4F5F4841412D0 wrote: Are there not two wooden bricks in room 17500 just below the blue key, Catwoman?
Brell, you're talking about the wooden moving platforms, right? They should be timed to avoid the pod going up through the middle. I've been through this a number of times and haven't run into a problem yet. Also, I gave myself four red keys at the bottom by the lift, and have tried that a number of times as well - all times successful.
If not the moving platforms, then the only wooden bricks directly below the blue key I see are in the background (layer 0).
I am talking about the wooden bricks below the blue key.  They are not moving and they are not in the background.  They are in layer 4:
5444535A5A360 wrote: I am talking about the wooden bricks below the blue key.  They are not moving and they are not in the background.  They are in layer 4.
Then I'm confused, because that's not what I see. I am looking at the room in question, and I used the eyedropper while in layer 4 and got no hits except for the moving wooden platforms, or the new vanishing blocks.
Edit: saw your image, but it doesn't match what I'm seeing. I don't have those wooden blocks. Instead, I have a third green block like the other two.
I believe the version you're playing Brell is out of date. Those boxes there aren't there in the 1.0.0 MM2 version.
OK so how do I get the correct version? Do I need a new code if I download the demo?
