06-25-2010, 07:33 AM
Post here for comments regarding the built-in mansion Castle Basano.
Beta 4: Castle Basano
06-27-2010, 04:33 PM
Just finished the Hard version with 100% secrets. Yay!
I like the improvements you made, Anthony. I think the difficulty level is all good now, IMHO. No problems found. 8-)
06-27-2010, 04:50 PM
Hard
Oh, I did notice that old music from MM1 is used in various places.
07-02-2010, 02:33 AM
17100 - Hard
I think that the grey panel door in this room should stay open when Jack leaves & re-enters after pulling the lever. 16504 - Hard I think that this is a layer problem. Not that Jack is stuck or anything. But Vern asked us to look out for this. If Jack stand on top of the vine, near the edge & jumps, he ends up...see pic Ok, finished with 90% secrets. hmmm? Love the changes. Especially the 3 Medusa's in the caverns, now there is only one & not rushing at you. But those 3 ghosts, in the cavern behind the red door, well, one of them got me. Jack could not jump over them. I was able to p/u all the coins in the zapper area, before I couldn't. Great Mansion!
07-02-2010, 11:33 AM
5C5543555D5D340 wrote: Map - Hard Missy, Jack can climb down through the bricks to reach the gray batmobile.
07-02-2010, 02:47 PM
5761696D294A65706D7261040 wrote: [quote author=5C5543555D5D340 link=1277451186/3#3 date=1278032467]Map - Hard Missy, Jack can climb down through the bricks to reach the gray batmobile. You are so good, thank you. What a sneaky spot! I removed my post re this subject, would you pls take this one out as well. Thank you. btw: I tested it out in the MLB.....that is so cool. heeheehee
07-02-2010, 03:29 PM
16504 - Normal
Ok, I finally found the missing 10% secret. see pic. This spot really should have a better hint. The distraction of those lady bugs takes away from Jack exploring jumping to the left of the vine mid-way up it. hmmm. The only way a player would find this room is to open up the MLB & since the area map is to tiny to see the secrets, he would have to click each room & enlarge it by opening it up, just to see where the secrets are. This is not good.
07-05-2010, 04:30 PM
Easy
Old music used, at least in the beginning part (first noticed in room 15293). 15296 (see pic) Jack can climb down through the bricks, but in Easy level there is no bat platform.
07-05-2010, 08:50 PM
Normal
Old music used, first noticed in 16298 and it stays in several rooms. Probably used elsewhere, too. 16300 (top level) Too many critters to avoid for Normal. Other than that, I think it's good difficulty level, and no other problems were found.
07-09-2010, 12:59 PM
HARD
Just finished, high score uploaded, no problems found. ![]() |
« Next Oldest | Next Newest »
