06-25-2010, 07:32 AM
Post here for comments regarding the built-in mansion Jasperlone Mountains.
Beta 4: Jasperlone Mountains
06-25-2010, 06:25 PM
Easy
14899 Jack stuck. Jack rode the yellow platform all the way to the top, explored around up there and then didn't have enough yellow keys to get out (see pic). He has nowhere to go.
06-25-2010, 07:58 PM
Easy
14105 Yellow platform from the top of the mountain stops here (see pic). Is it supposed to stop here? In Normal, it goes all the way down.
06-26-2010, 01:43 PM
Jasperlone Mt EASY
room14298 14299 Moving between those rooms make golden bricks change to grey. Grey bricks doesn't change to golden. :-[
06-26-2010, 07:09 PM
Hard
Wow, what a huge mansion!!! I love it, but I found quite a few problems. I just completed the left half, so thought I'd report those things now: 13894 The lever at top right doesn't seem to do anything. 13292-13293 Wind effect causes weird flashing (game glitch) when Jack slips back and forth between the 2 rooms. 12693 The ladder leading to the top of the summit is not complete at the top. Jack falls to his death when he reaches the top. 14496 Jack Stuck. Gray bat platforms only go down to bottom of this room. The check boxes to allow them to go to other rooms are not checked. 14695 Shouldn't the lever open the gray door? It now opens the red trap doors, but Jack is stuck at this point, without the gray door opening. 15094 Gray bat platforms are way too fast. 15293 Impossible to avoid getting killed, either by the scorpion or the medusa head. 15294 If Jack jumps left after taking the sinking tile to the bottom, I don't think he can jump across the acid safely. 14894 How does Jack get to the lever on the bottom left???
06-27-2010, 11:39 AM
Hard - Right Half
14506 How is the helpful troll supposed to get down to the bottom lever to open the last gray door? Jack can't pull the lever because of the zapper beam. The whole top of the mountain on the right side is way too hard. Too many critters to dodge while fighting the wind. If you keep them all, I think you need to add shields. 15501 All the backtracking to pull levers to open gray doors is kind of annoying. Now I'm off to try the extra challenge section. :o
06-27-2010, 02:48 PM
Hard - Extra Challenge Section
Whew! I had to cheat like crazy to get through this, or I never would have made it. 16702 Jack died a thousand deaths trying to make that jump. Never did do it. I gave myself a red key. 16901 I couldn't find a green key anywhere. When I arrived in 16099 I had one green key for that door. Should I have had another one at that point? Cheated by giving myself a green key. 17100 Couldn't make it through the zappers. Cheated by removing one. 17300 Levers on bottom left and top right don't do anything. I made the bottom left lever open the gray doors and the top right open the trap door. Don't know what you intended. But without opening the gray doors, Jack can't proceed.
06-29-2010, 09:49 PM
Hard
14298 - 14299 - 14300 - I'm blocked in these 3 rooms... Jack can't go back and can't go ahead. Semi-Native: did you solve this? How? Tks
06-30-2010, 12:05 AM
margherita, there's a helpful blue haired troll in that cage at the right of 14300. Use him to change the blocks for you, and be prepared to do a lot of precisely timed jumps.
Good luck! 8-)
06-30-2010, 10:12 AM
Oh! Thank you Semi ! I'm going to try...
« Next Oldest | Next Newest »
