Beta 4: Magma Peak
Post here for comments regarding the built-in mansion Magma Peak.
Hard
15897 Jack can still jump up to the top right ledge and fall to his death if he tries to go right.
16489 Jack can jump up and get the money without having to pull the lever to open the door (also in Easy and Normal, I think)
16097 - Normal
Bug:  If Jack comes into this room from the right & dies, he reappears on the right of the 2 barrels flashing.  But he won't stop flashing to continue the game.  see pic
I finally got him moving again, but only after I put the game on suspend & came back to it. hmmmm
0B0214020A0A630 wrote: 16097 - Normal
Missy -  I can't reproduce this - it works perfectly for me. I'd also be interested to know how you got two secrets by the time you got to this point. I can only find one (by going through the wall to the right of the chain in room 16301).
323F20373238373A37560 wrote:
Missy -  I'd also be interested to know how you got two secrets by the time you got to this point. I can only find one (by going through the wall to the right of the chain in room 16301).
I finally found the room number for the 2nd secret.  It's 16498.
You have to access it from the room above, room 16298.
17292 - NORMAL
Maybe I'm wrong, but the ghost sure does appear to fast to kill Jack.  I mean, Jack just outsmarted the Mother Spider above, rushed down the chain so as not to get killed, appears in this room & bammm!  The ghost kills him on the spot.  hmmmm
see pic.
17095 - NORMAL
see pic.  Killing the 2nd Medusa on the chain does NOT make any noise.  The 1st Medusa died in the fire lamps & it did make noise.  I tested it in the MLB and it does not make noise there either.
17494 - NORMAL
At this point, seeings that the maze has driven Jack mad (insane), perhaps you would consider a short cut to the pole rather than making Jack go thru the entire maze again?
see pic.
Ok, I'm finished NORMAL with 90% secrets.  Maybe that shield in the maze counts for some points?  I didn't pick it up as my Jack was frustrated in the maze.  btw mapman:  FYI: there is a secret area in the maze.
.png   Picture_1_110.png (Size: 19.53 KB / Downloads: 1)
.png   Picture_2_050.png (Size: 19.53 KB / Downloads: 1)
Easy
No problems found, except (as mentioned above) in 16489 Jack can jump up and get the money from the yellow platform, but the secret won't count unless he opens the door and goes in.
This affects all versions, I think.
Magma peak HARD
15897 Jack can jump up in the upper right corner. If he does he falls to his death. Either he shouldn't be able to jump to the next room or there should be a secret ledge with a lots of money there.
16096 One of the time after having killed the monster the yellow key didn't appear. Jack had to go out of the room and back in, then the key fell down to be taken! Is it a bug???
16299 Jack tried jumping to the left because it could be the right distance to the next room and it is a hard mansion. Of course he fell to his death but got a blue key in room 16498. If he does a thing like this he should die earlier so he can't pick up the key first.
70796F797171180 wrote: 17095 - NORMAL
If you're talking about having Jack run directly into the 2nd medusa head (whether he has a shield or not), then you are correct -- it won't make a noise. The screaming noise is due to the medusa head hitting a flame. It'll only make this special noise when it dies on a flame, not when it dies by colliding with Jack.
4954485E3B0 wrote: 16096 One of the time  after having killed the monster the yellow key didn't appear. Jack had to go out of the room and back in, then the key fell down to be taken! Is it a bug???
Maybe you hadn't also dropped the skeleton spider that's on the top ledge into the lava, too? Both of them have to die for the key to appear.
