Where to put discussion about the sequel and sequel CM's
Hi.
When MM2 is out there will be a lot of discussion and builders will start building new mansions. Instead of making new categories I propose that we use the
Midnight Mansion sequel
category for discussion of the included MM2 mansions AND that general discussion of MM2 CM's will be in the CM Talk category. While we can make a separate category in the downloading area I think that we should try to use existing categories for discussion of individual MM2 CM's instead of spreading the category tree any further.
Yes, that should work. If people start getting confused, we can always separate out more categories in the future, as needed.
Individual CM boards for MM2 can state in the heading that they are for MM2.
So, MM2 is out. We have to change the forums up a bit. New categories for MM2 should be added, right? And the testers forum will be deleted, correct?
And who is going to do the updating?
Maybe I can do something about the old MM1 discussion categories. Anthony, can you add categories/boards for MM2 in the way you have proposed?
Alright. Will do.
Okay, I think I'm done with all the updates for now. Once we get some mansions from designers for MM2, we'll see what we do with the MM1 mansion categories and everything.
A very nice approach, Anthony. Later we may want to make some changes due to how everything evolves. Just one thought: In MM2 there are indeed two custom mansions: My TC&TC easy to hard and Trigger Island. Should we keep discussions about those two with the included mansions discussions or move them to MM2 CM discussion. I think the former is better as the latter may cause some confusion.
I will start working on the MM1 CM layout this weekend.
Since Caves & Castle and Trigger Island are in the Custom Mansions folder, I think they should be under the CM discussion. And if that happens, Anthony, I think you should change the text in the header that now says MM2 doesn't have any custom mansions. I think that is confusing.
Good job updating the forums, Anthony!
[smiley=thumbsup.gif]
