3B3224323A3A530 wrote: My appologies,
Hope you get well. I removed all my posts. I will leave testing your mansions to move qualified persons.
Missy, that was not how I meant it. I think you are just as qualified as anybody else.
I simply preferred if you'd try out a little longer before reporting some of your findings.
Please continue testing TI if you want and feel like it.
Here are my answers to the first part of your findings (I copied them off here earlier today and have answered them now).
Some of them are good examples of what I meant: (my answers in BOLD black)
13104 - When Jack jumps onto the save (not activating it) & jumps again, he ends up on the ledge above.
That is done on purpose - providing a means for Jack to get back to the middle floor - if he wants.
You/He can go back...... (see below)
13103 - Since Jack landed on the upper ledge in 13104, now he goes back to this room to get down to the save again, but he can't because the grey door won't let him. It was activated on his way to the save. I did find another way tho & that way too has a hidden grey door blocking access to the save. 2 grey doors blocking the save. There is NO WAY to get to the save now, that I can find. hmmmm
That is not correct. There is a way to get back to the save pedestal.... You just have to find out HOW.
Gosh, I really hate those coloured blocks, they are just way to fast.
Personally, 2 eyeballs & a moving platform is really overkill.
There are enough (hidden) shields provided for Jack to get thru that bit unharmed.
13102 - Not sure, but the brick on the far left (with the fire, under the statue), with the steps leading to it, well, it looks like a solid brick to explore, but Jack dies. hmmm
- Also, it would be nice if the moving brick came down low enough for Jack to jump on it from the top of the pyramid rather than having to go all the way around again. (sorry if this is not a good idea, but I have been going around in circles trying to get to the closed off save area & have lost my bearings.)
No, no no! First - the thing in front of the fire is just the cover of the fireplace
and in IMHO one can see very well that this is NOT a solid brick.
Second - it is on purpose that Jack is NOT ABLE to board the platform from the pyramid
- it simply wouldn't make sense (it's part of the quiz
& challenge of the room that he has to go thru the different (floor-)levels and finally activates (and boards) the platform from the topmost level. Don't forget - this is a hard mansion... ;-)
13701 - see pic, Jack exploring again & when he jumps back up from a certain spot in that dug out, he lands on the extremely fast bat brick, tries to jump off and dies. see all the bodies?
Well..... the far left end is where you activate a return elevator
in case you need to get back up. Simply avoid it when you don't need to get back up.
(Should you have accidentially activated a return platform, just step off it a.s.a.p. and nobody will get hurt - but the platform travels up empty
, making room for Jack to pass thru.....)
I simply needed a (secret) spot to allow Jack to activate a return platform. Only thing I could do here - I could make the return platform go slower, so lesser skilled players will have enough time to jump off without dying.
13506 - room below this one. Bird kills Jack in elevator. It can't be avoided. Is that what they call a cheap death?
NO - It's not - Cause it can be avoided - Jack has to stand on the left side on the elevator + maybe duck a little. There's enough time to see the bird coming...
14705 - Altho, BB's are not my forte, pls check it out in this room: Should start with capital You.
Also, I checked the other day for the right spelling for the Bat Mobiel or Mobile. Seems that the internet has both ways of spelling it. hmmm
In 14705 there is a BBB - but the word YOU does not appear on it - neither w/ or w/out a capital Y ;-)
In case you are referring to the BBB in the next room (14704) - the spelling is correct, as the phrase starts with: Wanderer, you should....
In my understanding of the English (or any other) lamguage, a capital Y would only be required if the word you was the first word of the sentence.
Whaat - who said Bat Mobile? (BTW - I consider Mobile to be the correct way of spelling it) - I had never called them Bat Mobile...... I called them Speed Mobiles.
14705 - I JUST LOVE THAT YOU USED THE BAT MOBIELS INSTEAD OF MAKING JACK WALK. YEAH!!!
14702 - I know that the BB said not to get off the bat brick, but Jack did and ended up here (see pic) The grey door is a half door. Now he can't get back down, no bat brick.
WELL - Please follow my instructions on the BBBs. That's why I put them there...
BTW - the grey door is not a half door - it's just small.
In this case I can't help you - you have always suicide as an option !
14105 - Am I missing something? What is the purpose of the goblin? Jack can open the grey door himself???
Yes he can, that's right. I was just having a little fun with the small guys.... PLUS in order to help weaker players
not risk their lives when they go near the new medusa head to activate the white footswitch, I supplied them a helping troll to do it for them.
Do you think it's too confusing?? Then I could erase the helping troll !?
