Jack stuck?
Please see the attached screen shot. Jack can't find his way out of where he is. Am I missing something?
Thanks. This mansion has a lot of surprises! Loving it.
how did you get there if you can't get out? The only possible way should be to go back the way you came, considering the state of the room. How else did you get in there if not from the right of where you're standing right now?
It seems you managed to avoid pulling a lever, I thought levers were impossible to resist, should have made the lever do things one of the floor switches does to avoid this Smile
Strange, I actually remade this room to avoid this situation Smile
Fixed it, sent an update to the admins
Jack jumped in there somehow, from the right when he got to the top of the ladder.
I'm an admin now, too, and I uploaded your mansion, so you could have sent it directly to me. Just for future reference.
it's not hard to jump in there from the right, but you can't get further without pulling the lever
and now it seems too late for that Smile
I sent the update to you too, then
This Jack stuck has been fixed and the mansion updated. Visit the download page to get the latest version.
756E7D1A0 wrote: It seems you managed to avoid pulling a lever, I thought levers were impossible to resist, should have made the lever do things one of the floor switches does to avoid this Smile
I quote myself:
Never ever assume that the player will play your mansion in the way you intended. If there is a strange/stupid/whatever play that a player can do be sure that someone eventually will make that play. Remember that the player cannot know beforehand that the play will lead to JS or cd.
We had a JS in this room during beta, but this other one seems to have slipped through Smile
your quote is always worth mentioning Smile
Olle, sorry to tell you this, but once again, Jack got stuck in the very same spot. This time, he came down from above and fell into the same area. Since he hadn't been to the area where he could pull that lever yet, once again he's stuck.
I think the problem lies in the fact that when Jack falls, instead of dying, a lot of times he ends up sliding down a pole, and ends up in an area that you hadn't intended.
Maybe the solution is doing away with having to pull that lever to get out of there?
but now you really have to tell me how you managed to fall all the way down there and not die?
please describe the situation, since I cannot make him fall from above, nor the side, into that spot... without dying trying
This mansion is made to be exactly as you describe, if he falls he is supposed to survive and be able to explore something else, or need to go back to try again
but not survive when falling to his death, as this should be
I didn't want to say exactly how Jack got there because I didn't want to give away anything, so I'll PM you.
