First of all: Nice job! My Jack chased through your mansion like he meant it and had real fun on the way!
There are two minor issues: In room 19114 the gold bag on the bottom left seems to be between two solid brick walls. Was it meant to be that way? Or am I just too stupid to find a secret access?
Also: If you go back from 18915 to 18914 while the gold bricks are switched on, Jack falls to a cheap albeit painful death. :'(
Sorry it's taken me so long to get a new version to the admins. I started making a few other cosmetic changes and then lost time. I have fixed those problems and will be sending an updated version of the mansion shortly.
I found a possible game ending Jack Stuck I'm afraid. if you die in room 18513 with the blocks in the gold position there is no escape, at least none that I can find. here is the attached movie
I have a couple of questions to understand how you got there. If I understand, you died in Room 18513 with the gold bricks on -- correct? My confusion is how you are on the middle row. Did you enter 18513 on the middle row? I'm trying to recreate and I don't see a way to enter the room on the middle row with the gold bricks on. When I enter at the top and die, Jack reappears on the top row.
With more than 14 years of delay :-? I may confirm that there indeed is a Jack-stuck in room 18513. It goes this way. The first time Jack enters the room from above with the right ladder and the blocks are gold. Jack has stuff to do in the room to the right: 3 keys to catch. So he has to use all three floors to go to the right. And back. The top floor gives no problem, but when Jack re-enters from the right on one of the other floors this may happen. With blocks on silver Jack uses the ladder(s) to the top floor, then goes left to pull the lever to change the blocks to gold and then stumbles into the gap and dies on the bottomfloor. Jack reappears on the midfloor at the right where he previously re-entered the room. See picture 1. He is unable to get back to the ladder (upper right) to continue game. The game has to be restarted from the beginning or a saving point.
I also noticed another (double) JS in room 18708. Jack is able to arrive right from the green door while having no green key. When going up with the wooden platform Jack may jump on the top of the closed green door and then stepping to the right. Or he jumps to the bricks on the left, then to the right and at last he has a safe jump down to the right. In both cases he is locked in behind the green door. On the second image you see how it may be fixed.
At last there is also an odd cheap death (half Jack-stuck) in room 18912. See pic 3. Jack came in from the right and jumped on the moving platform. While standing on the left edge of it he went down passing the concrete floor and could jump either right or left to avoid an immediate death. No help however. He has to jump in the deep or the lava to contine game. Or game over; I may not forget that.
7D747E110 wrote: … Also: If you go back from 18915 to 18914 while the gold bricks are switched on, Jack falls to a cheap albeit painful death. :'(
Because I did find a few issues myself, I also checked earlier posts about JS’s or CD’s. About this message I may assure that there are no gold/silver blocks in the rooms 18914 and 18915. But! The situation exists. At the enclosed images you see the rooms 18312 and 18313. In room 18312 there are goldblocks at the very right edge of the top floor. So when Jack comes in from room 18313 he doesn’t find a floor but ‘walks inside the concrete gold blocks’ what makes him fall one or two floors down. Easy to fix.
