Slowly running windows
I recently upgraded my computer, and am running an imac with leopard 10.5.5. I find that certain windows run quite slow when playing MM.
Any ideas?
Hi Charles, and welcome!
Did you upgrade to an Intel Mac from a PPC? If so, there are 2 versions of MM. You should run MM for Intel, if that's the case. Hope that helps.
Hi and welcome!
Also update the MacOs to 10.5.8!
I have Snow Leopard (10.6.2), so if you let me know the Mansion's name, AND the room numbers that are running slowly (push Command-D to display the numbers in the upper-left corner of each room), then I will look into it.
