07-05-2009, 03:49 PM
I just saw that vers. 1.1.8 is downloadable!! It has been for 2 days!!!
version 1.1.8 is here
07-05-2009, 04:03 PM
Thanks, rose!
07-05-2009, 06:55 PM
Thanks! Downloading now.
07-05-2009, 11:02 PM
???? I am still using version 1.0.9, and everything works great (as far as I know).
I am still very much a computer newbie, and terrified of most system upgrades, deleting programs, moving stuff, etc. Can anyone tell me if I need to upgrade to the 1.1.8 version, and if so, how to do it for 'computer iMac Dummies'. ? [smiley=embarassed.gif] Thanks ahead of time, [smiley=dankk2.gif] SandyBean [smiley=2vrolijk_08.gif]
07-06-2009, 03:35 PM
While I do not always find it necessary to keep all my software at the latest version, I always do update my MM application.
Most of the time it is only one or two smaller issues that Vern has repairedwhen a new version comes out..... however there have been some update-steps in the past that have been very important. As you are really quite much behind (you're even below 1.1.0 !!), I'd really recommend that you update several steps. Every update-version is a COMPLETE version of the program....so there's not much that can go wrong. However, you must take care to move all the Custom Mansions from the older folder into the newest update. Manually ! What I would do: Leave the old version on your Mac until you have installed and tested the update. Try this: Download the latest version (provided it's compatible with your version of the Mac OS !), and from the unzipped disk-image that appears after the download, copy the MM application 1.1.8 into your Applicationsfolder - right next to your version 1.0.9. Next, drag or copy the content of your old Custom Mansionsfolder into the new Custom Mansionsfolder (within the 1.1.8 application folder). Start the new version and try to play a custom mansion once MM has started..... if that works fine you did everything correctly. It's simple, isn't it?? ![]()
07-07-2009, 06:26 PM
Hi aquaMat,
Thanks So Much for the excellent and easy to follow instructions, I have printed them off so when I gain the courage to try it, I can follow them to the 'letter'. Have another question though, when I looked through my computer, I found another folder labelled MM in my 'home section' (called forward5, See attached pic) when I go to > Library >Application Support > MM. This MM folder contains things such as 'MM High Scores', 'Player Profiles', 'Saved Games', 'Output File Log', etc. Will this all be automatically saved or updated along with the installation of the new MM version 1.1.8, or do I need to do something here too? Sorry for all the questions, and I appreciate your help so much, just such a 'newbie' at all this stuff ! ![]() thanks and take care, SandyBean [smiley=2vrolijk_08.gif]
07-07-2009, 06:46 PM
Don't touch that folder. It has the data of saved games among other things. It is the info you want to keep.
07-07-2009, 07:18 PM
Like rose said, you don't have to do anything about the folder in Application Support.
The MM updates have always gone smoothly for me, you don't have to worry. Just remember to move your custom mansions from the old version to the new one. Then after you're sure the new version is working fine, you can trash the old version's folder from your applications folder.
07-07-2009, 11:21 PM
Ze folder with ze high scores, profiles and such, are always going to be the same. The only thing that needs to be updated is the Midnight Mansion applications and the midnight mansion data, pretty much.
07-09-2009, 03:10 PM
I DID IT.... I DID IT ~!!! ;D
Thanks aquaMat, Rose, Semi-Native and Wingy...........with all your great instructions, it really was a breeze, and I didn't accidentally delete anything ! Yaa Hoo ! But, I didn't really notice much difference either, but I guess since I am still playing the ComplexJack and I may not have run up against any glitches......it was designed by aquaMat after all! ![]() Thanks Again, and take care All ~ SandyBean [smiley=2vrolijk_08.gif] |
« Next Oldest | Next Newest »
