Falcon Mansion Easy, help please
This is my last easy mansion but it is not easy at all.
The other post indicates that it is possible to see the entire mansion.
-Is this true?
-Does it matter if I take the red door or the blue door, to visit the red or the blue house first with the multy colour key?
-If you go right: the maze with all the gray doors: At the end it seems impossible to go further. Does this mean you have to come from the other side somehow to open them?
All tips are welcome cause I'm not getting through after the second save.
You can visit all of the rooms, but it is not possible to open all of the doors.
I don't believe it matters which door you go through first. I always take the red door just so I'm putting off the grey door puzzle area. Undecided The puzzle area is difficult, especially for beginner players. I know it took me awhile to figure it out and get through it.
Sorry, I'm not sure I understand your last question.
Well I first took the red door en blue area. After that the blue door and worked out the gray doors area. But now I'm stuck in 19096 with the 2 big zappers. Are you ment to cross that??? I can't do it. I want to go right in that room. No where else to go. For tonight I give up. Help would be appriciated.
No, you can't cross those zappers. To get to the other side you have to come from the other direction.
OK, After tonight I officially hate Falcon Mansion. I give up.
Don't give up. You say you've been through both sides? Just go back up, go to the other side and come back down.
Good luck!
It's just so frustrating. I first do the red part and use the red key to do the blue. I make it to the fare right (through the grey doors) (I don't have 2 yellow keys for the litttle room). I go down a bit at the right. Then I turn back to the room with the 2 big zappers. No crossing right? The room beneath: I do have 1 purple key but I cant make it to the right side of the room to go up again.
And room 19098: don't you have to come from the left (and with a visible bridge) to get the money? I can't figure out the route you are supposed to take and again I'm stuck with 1 purple key left.
Bleach wrote: It's just so frustrating. I first do the red part and use the red key to do the blue.
How do you do the blue part with a red key?
Bleach wrote: I make it to the fare right (through the grey doors) (I don't have 2 yellow keys for the litttle room).
You only need one (there's another yellow behind the left door]
Bleach wrote: I go down a bit at the right. Then I turn back to the room with the 2 big zappers. No crossing right?
By
go back
you mean that you go all the way back to the red part and go in there, from the left?
Bleach wrote: The room beneath: I do have 1 purple key but I cant make it to the right side of the room to go up again.
You're not supposed to do that, you're supposed to go down from above right to get the red key behind the purple door.
No, you're supposed to come down to 19098 from the room above (18898), and then left over the golden bridge to the room with the big zappers (19096), but from the right side this time, through the purple door and then get the red key to go down the pole in the rightmost room (18901)
Hope this helps some
I do appriaciate the help. But since the suspend game doesn't seem to work, I have to replay a big part to get to the point to look up the room numbers you mention. And the grey doors which I managed to pass 2 times before, this time wont do what I want them to do. So again I give up for today extremely frustrated. I pulled all the handles a million times in different order but I can't get the blue key.
Bleach wrote: And the grey doors which I managed to pass 2 times before, this time wont do what I want them to do.
Falcon Manor Easy was the first mansion I ever played [and after playing the free 20% I bought the license immediately and played all night Smile] and those grey doors frustrated me too until I realized that there were someone who'd been thinking before making those rooms... Spending some time carefully noting what each lever does, the pay is seeing how one *must* pull to be able to get to the key.
I have to keep the silver blocks visible when pulling the lever with the purple marking to be able to get to the next room and the lever with the blue so that I can get back and change to gold and then go back in the level below to pull so that I can go down one level and pull and then go back up to get the key
The reward is double. Both the mental satisfaction of having solved a puzzle, and the excitement of being able to continue exploring the mansion.
The key is to not give up, but be watching carefully what is happening around you
