Perpetuum Mobile - A few words of guidance
Dear friends,
I thought it might be a good idea to give a few words of advice about my latest mansion, Perpetuum Mobilé.
This mansion is somewhat unusual in that the player has to master quite a distance until the first save comes, but after that, as the challenges keep coming, there are more save pedestals than usual, so he can feel free to try some more adventurous moves etc.
There is also more money than usual to be had here, so the player will not lose patience or interest, simply because he runs out of lives too soon, too often.
Also, for a mansion of about average size (close to 100 rooms), there is quite a high number of secrets. So it is wise to look carefully for hidden coins, secret passages and other mischievious ocurrences.......  8-)
While there are several
Mobiles
, self-powered moving apparati, throughout the mansion (in fact right from the 1st room on), there are a few bigger ones in the central section.
Not all of them are obvious from the first glance...... one of the hardest might be the big
grey structure
that extends over several floors/levels.
To make it somewhat easier, there is one save right before, and one after it. Both of those can be used whenever the user feels he needs them.
And one final hint about this
grey structure
 (I use this peculiar name for fear of giving too much away):  One or two levers there can be pulled, but they also can be NOT pulled.....depending of whether you think it helpful or not.
If you're there, I guess you'll find out what I mean by that.
Well then, let yourself be (infinitely) moved....by the Perpetuum Mobilé !   Wink
Guten Tag Matthias,
I am enjoying this mansion! Wunderbar! I haven't got to save point one yet, I'm as far as the room with all the yellow keys. Smile
More MM playing tonight! I'm off out for a day mit meine tante, onkel und gross-mutter (spelling?!).
Tschus! Big Grin
Thanks, Lara !!
I'm gölad you like it....! Smile
Your German is not bad !!
Hallo!
I'm in 18894 and a little stuck. I will keep trying to jump onto the pink brick. Are there any other options? Smile
HELP!!!!!!!! Undecided
I admit this is a somewhat tricky part in PM.
But once players have found the solution it actually becomes quite straightforward and, ahem, easy.
What I can tell from the above picture is, that players having difficulties there SPOILER:  simply have not yet discovered that there's another moving brick to be activated somewhere !!
Look more carefully everywhere in this room......   Wink    8-)
BTW:
The reason why I couldn't reply sooner is I'm down with a heavy flu and considerably raised temperature.......
(That also applies to enquiries sent in to me via Mail or PM. Though I'll try to answer them later tonight.)
Oh yuck, the flu! Feel better soon, aquaMat!
Tongue
