Final Candidate 1: All Comments Go Here - Printable Version +- Midnight Mansion Forums (https://actionsoft.com/forum) +-- Forum: 120 (https://actionsoft.com/forum/forumdisplay.php?fid=10) +--- Forum: 999 (https://actionsoft.com/forum/forumdisplay.php?fid=55) +--- Thread: Final Candidate 1: All Comments Go Here (/showthread.php?tid=1417) |
Re: Final Candidate 1: All Comments Go Here - Wingy - 08-26-2010 Wow, that's quite the mansion. Just finished DDDH with 85% secrets, no problems found. Your storyline was quite funny, fun and thrilling.
Re: Final Candidate 1: All Comments Go Here - Semi-Native - 08-26-2010 Blackheart Keep Hard, no problems. Only got 81% secrets, though. :-X Re: Final Candidate 1: All Comments Go Here - rose - 08-26-2010 Semi-Native, could you have a look at the two places where I had JS. I don't have time to start DDD HArd from the beginning and I can't start it from my saving points with the new version because I get the message that it is tampered with and I have to use Start custom mansion. Re: Final Candidate 1: All Comments Go Here - Semi-Native - 08-26-2010 rose, you mean 16510? Those bat platforms have been replaced by yellow platforms with levers to start them, so that's fixed. Was there another one? Re: Final Candidate 1: All Comments Go Here - Semi-Native - 08-26-2010 Do any of these still need to be tested? Castle Basano Normal and Hard Jasperlone Normal Leofani Hard Caves & Castle Easy and Hard Trigger Island (that's been tested extensively, so unless aquaMat made any changes, that one's good) Re: Final Candidate 1: All Comments Go Here - rose - 08-26-2010 Thanks! The other room was 15708 Re: Final Candidate 1: All Comments Go Here - RobSeegel - 08-26-2010 574A5640250 wrote: Thanks! That problem no longer exists, Rose - the area was revamped, and I had your report partially in mind when I made some of the changes... Thanks for reporting it
Re: Final Candidate 1: All Comments Go Here - rose - 08-26-2010 Great Rob! Now I can concentrate on work instead of MM. ;D Re: Final Candidate 1: All Comments Go Here - RobSeegel - 08-26-2010 Semi-Native: Can you check something for me please? The room that had all the eyes and trapdoors towards the end (area 5). The gray door in the middle should be closed when Jack starts that screen, but I was doing some checking there, and I'm afraid I may have left it set to open. Re: Final Candidate 1: All Comments Go Here - Semi-Native - 08-26-2010 477A77467070727079150 wrote: Semi-Native: Can you check something for me please? The room that had all the eyes and trapdoors towards the end (area 5). The gray door in the middle should be closed when Jack starts that screen, but I was doing some checking there, and I'm afraid I may have left it set to open. If you mean 16507, it's okay, it's closed. |
