Final Candidate 1: All Comments Go Here - Printable Version
+--- Thread: Final Candidate 1: All Comments Go Here (/showthread.php?tid=1417)
Pages: 1 2 3 4 5 6 7 8 9
Re: Final Candidate 1: All Comments Go Here - Wingy - 08-26-2010
7E4D5A46624D465B4D46280 wrote: Rob suggested giving players a hint about the new ability for Jack to read things other than signs in some mansions (pedestals, for instance). I added a pedestal to the Tutorial mansion just now, but I'm not sure I came up with something good. Here's what I've got -- my attempt at a joke. Can anyone come up with something better? Heh.
Inscribed on the pedestal you see what appears to be some crude writing:
Pedestal - $300
Suit of Armor - $650
Providing decor to countless mansions - Priceless
This is for room 15702.
Sounds good to me.  ;D
I was playing Leofani Manor and Jasperlone the other day, and there are many times where I have a sign near a pedestal saying 'Here lies Legbert Leofani... etc'
Would it be too much trouble if you could (with the glove tool) move the sign on top of the pedestal and make it invisible? I'll give you a list of the places: (just a couple, won't take you more then 10 mins)
Leofani Manor Easy / Normal / Hard
15904 - Put under a bookshelf, make invisible.
16104 - Put on the statue and make invisible.
Easy Only - On the tree put the sign and change the sign to:
Welcome to Treasure Island
Hard Only - 16697 - Move the sign to the left until it's right on the edge then make it invisible.
Hard Only - 17511 - Move the sign closer to the chair, but not too close. Move the gold coin or money bag over by the sign then make the sign invisible.
Hard Only - 17514 - Add some cracked layer 0 tiles on the wall and make the sign invisible; to make it look like inscriptions on the wall.
Jasperlone Mountains Normal / Hard
14307 - Make the sign in invisible.
15894 - Here's one of the biggest places I have signs beside of statues and whatnot. On the left, move it onto the dude holding the skull statue and make it invisible. The one to the right of the knight statue is for that guy, and the gargoyle doesn't have a sign for him... hmm. How about we put one in that says:
Leginstien
Legbert Leofani's masterpiece creation.
Last known whereabouts: Leofani Manor
15895 - Just move each sign unto the statue to the left of it and make them invisible.
15896 - Move the sign to the left of the statue onto the statue and make it invisible. The other two signs I would prefer (you don't have to) if you could remove the layer 6 on the bookshelf and have the signs invisible. Use layer 5 to fill in that top-right hand corner of the bookshelf brick and it should all be good. Try to use the box tool with the nothing tile selected so you don't delete the sprites.
Hard Only - 16700 - Sign invisible please.
And that's it for my mansions. Tongue
Re: Final Candidate 1: All Comments Go Here - RobSeegel - 08-26-2010
4A777A4B7D7D7F7D74180 wrote: I just finished doing a pretty comprehensive walkthrough, and fixed many small... and a few not so small things that have found their way in recently with some changes that have happened recently. I tried lots of different things, including doing things out of order and differently than I might normally.  If I had the slightest doubt about something or it gave some trouble - I got rid of it, or made it easier.
There should be 80,0000 treasure, I double-checked the secrets (which were off because of recent changes), but I believe all the big things have been fixed. Please prove me wrong.
The version for the mansion should say 2.1
All object ids have been reset.
If you find anything major, please post here, and ensure Vern sees it. I will be checking in periodically from work, but won't be able to do anything from there. Feel free to suggest fixes for major issues if there are any. I have a software release I'll be overseeing today that's been a while in coming (coincidentally enough).
Re: Final Candidate 1: All Comments Go Here - margherita64 - 08-26-2010
Blackheart Keep Normal
No problems found
Re: Final Candidate 1: All Comments Go Here - Semi-Native - 08-26-2010
Jasperlone Mts. Hard
No problems found, and believe me, I tried to get myself stuck due to wrong key combinations, etc. All was good. Only got 90% secrets, though. Tongue
Starting on the latest version of Dr. Demented Hard.
Re: Final Candidate 1: All Comments Go Here - rose - 08-26-2010
Dr. Dem HARD
16510 JS, Went up the rightmost grey brick then down with the one just left of the right one. Comes down and can't get any new brick to move up again
Re: Final Candidate 1: All Comments Go Here - VernJensen - 08-26-2010
Hi Rose,
You're using an older version of Dr. Demented's Den HARD. Look on page 5 of this thread, at the bottom -- you'll see a post from Rob with a version he posted this morning. Could you please test with that?
FYI -- I will be doing some final wrapping-up of the game, and likely starting the release process within a few hours. Sounds like Semi-Native is testing the latest DDD Hard right now, and I'll likely test some portions myself too. Once that's done and I hear back from at least one other tester (although two would be ideal!) that this mansion is a go, then I'll release!
Anthony - yes, I'll make those changes.
Just finished DDD Hard with 95% secrets. No problems found, I think we're good to go!
0C3A323672113E2B36293A5F0 wrote: Just finished DDD Hard with 95% secrets. No problems found, I think we're good to go!
Thank you! I'm hoping for at least one more report from someone else.
