Final Candidate 1: All Comments Go Here - Printable Version
+--- Thread: Final Candidate 1: All Comments Go Here (/showthread.php?tid=1417)
Pages: 1 2 3 4 5 6 7 8 9
Re: Final Candidate 1: All Comments Go Here - divadnala - 08-25-2010
Dr Demented's Den EASY
No problems found
Re: Final Candidate 1: All Comments Go Here - jamesbolton@cox.ne - 08-25-2010
Hi Rob
in DDD hard (yes 008) silly man that I am, I went down the bottom ladder in 16701 before pulling the lever to open the gray door. Did the lower level and went out left came up on the platform went right and ended up in 16700 with Mr Blue Hair tried to exit right and came up against the closed gray door. No way to return. Damn
Regards
jim
Re: Final Candidate 1: All Comments Go Here - Semi-Native - 08-25-2010
Dr. Demented's Den Normal
No problems found.
Magma Peak Normal
No problems found.
Jasperlone Mountains EASY
The version of Jasperlone in Final Candidate 1 is the one with the potential JS reported yesterday (this thread reply #6) and not Anthony's more recent one (this thread reply #9).
Apart from that no problems found. An excellent mansion.
Magma Peak Hard
No problems.
Citadel of Dr. Cassiopus Normal
No problems.
Re: Final Candidate 1: All Comments Go Here - margherita64 - 08-25-2010
The caves and the castle normal
No problems found
Leofani Manor Normal
No problems.
Re: Final Candidate 1: All Comments Go Here - RobSeegel - 08-26-2010
3E35393127363B38203B3A14373B2C7A3A31540 wrote: Hi Rob
in DDD hard (yes 008) silly man that I am, I went down the bottom ladder in 16701 before pulling the lever to open the gray door.  Did the lower level and went out left came up on the platform went right and ended up in 16700 with Mr Blue Hair tried to exit right and came up against the closed gray door.  No way to return.  darn
Regards
jim
Thanks, Jim - unbelievable that that's gone unnoticed the whole time (it's not a recent change). I just took out the door. The lever that opened it was in the same room, and was as much a challenge as getting to the doorway was (not much), so it seemed overkill having it there.
