FACES - Printable Version +- Midnight Mansion Forums (https://actionsoft.com/forum) +-- Forum: Discussions of approved MM1 and MM1 HD custom mansions (Mac and Windows) (https://actionsoft.com/forum/forumdisplay.php?fid=11) +--- Forum: FACES exp. / normal (https://actionsoft.com/forum/forumdisplay.php?fid=98) +--- Thread: FACES (/showthread.php?tid=198) Pages:
1
Re: FACES - aquaMat - 02-02-2007 Fellow mansioneers, FACES has gone through 2 updates, has even become a little bit bigger, and will soon be on the officiallist. Please do NOT download it anymore from here, just wait 1 or 2 days and get the release version. Thank you. EDIT: Attachment has been deleted in the 1st post of this thread, as FACES is now downloadable from the OFFICIAL LIST. Re: FACES - Sharpie - 01-31-2009 Very nice mansion. I finally won. I did find a JS though in Room 15103. I didn't jump far enough in the room above to land on the lower bricks. Re: FACES - Sharpie - 01-31-2009 Here is the screenshot. Re: FACES - aquaMat - 02-01-2009 Well..... this is really unusual. Normally you should die when you miss the jump.... you just happened to accidentially land in that tiny opening (where one brown brick is missing (for design reasons) !). But one little move to the left or right and you die eventually, and then you're hopefully reborn safely in the room above.... so I'm not sure I'd call this a JS in the truest sense. 3 minutes later: I checked the mansion again and tried to duplicate your behaviour.... and I managed to land in the same spot. I moved a bit and died.... BUT: unfortunately I wasn't reborn in the room above (even if the software is programmed to let rebirths always happen in a safe place). So....it seems as if I have to do an update soon, where I get rid of that tiny opening (which is a shame.... I always include irregularitieslike that, tiny openings, miscolored bricks etc. to make my designs more natural. and more believable). I will come up with a solution, however..... but it will have to wait until I have my new mansion, Les Catacombes Rouges" ready for release (at the moment it is beta-tested). Then I will send both mansions to the admins for release. Re: FACES - aquaMat - 02-02-2009 Las t night I fixed this potential JS in both versions of FACES. While I was at it I discovered that there were several layer-0 / design imperfections in both versions, which I have also fixed. I also finished my update of The Mansion Family: A Wondrous Place. Maybe I will send those 3 mansions to the admins even before Les Catacombes Rouges is ready for release. Keep an eye on the list..... Re: FACES - aquaMat - 03-16-2009 Apparently my recent (not yet published) updates of FACES normal, FACES hard and TMF3 - A Wondrous Place have got lost during Brell's computer crash/problems, but I have sent them to him again a few days ago. So I'd think thy'll be up for downloading pretty soon....in case you have wondered (where they've been) ! :-?
