Beta 4: Citadel of Dr. Cassiopus - Printable Version
+--- Thread: Beta 4: Citadel of Dr. Cassiopus (/showthread.php?tid=1379)
Pages: 1 2 3
Re: Beta 4: Citadel of Dr. Cassiopus - hawaii - 07-02-2010
16314 - Normal
Is there a room missing?  see pic of map.  It is located under 16314.  There seems to be grey doors on either end of it.  Just wondering. (Wasn't there a room in beta 1?)
15918 - Normal
There seems to be a jumping problem off the step in the pic.
Jack hits his head & dies in the water.  This spot is very deceiving, as he does not his his head off any other step.
This is an overlap problem???  If he is not meant to go this way, there should be a block at the beginning and not only in one spot.
15917 - Normal
Jack can p/u the red key in the room below, by just falling to his death from the vine in this room.  Perhaps a block of some kind could prevent this?
16108 - Normal
Overlap problem that does not exist in the Hard version.
At the top of the vine, on the left, Jack can land on the bricks. But on the right, he can't.
16120 - Normal
Jack can't get the last Gold Coin out of the tree.  see pic
16319 - Normal
I still feel that the sign reminding Jack to have his red keys, should state the number of keys needed.  If he goes down the pole, he can't get back up to retrace his steps for the missing key.
Turns out that Jack needs 8 keys.  I only had 7.  That is why the sign really should state the number of keys.
16519 - Normal
Nothing happens when Jack slides down the pole & reads the sign.  BUT, if Jack starts jumping to the right, all of the sudden, there is a sound (so quick) a bird shoots out and kills him in the middle of the jump.  If the sound were off, THIS BIRD APPEARS WAY TO FAST, LIKE A JET.  For me, this is a cheap death.
OK, I FINISHED THE GAME WITH ONLY 75% OF THE SECRETS.  Too bad that the map is not available after Jack goes thru the exit door, so that one can see what one missed out on.
HARD VERSION
16305
The switch on the far upper left does NOT turn the fire lamps back on & the Medusa kills Jack while he is still trying to figure out if there is a hidden lever or something.  The switch on the far right shuts them off as he leaps to the left.  (Top level)
16308
I can't check this out in MLB as the room is dark.  Pls note that the ladybug's timing on the vine after Jack jumps to the upper ledge on the far left, which activates the Medusa, prevents Jack from either jumping up or down on the vine & the Medusa just corners Jack on the ledge and kills him.  The fire lamps don't help at all in this instance.  hmmm.  Pls don't tell me that a player needs to be fast.  This spot is a death trap, period.
16707
see pic below.  The yellow brick appears after Jack explores the upper right ledge.  He then goes back down to get the bat mobiel to go up, but the yellow brick prevents it.  The only way to get it out of the way is to leave the room and reset it.  Perhaps you can use a disappearing brick instead?
15512
The vine under the purple key is not that great.  Kind of to short when Jack jumps from the left to the right, & they are both sort of stuttery.
15712
Jack pulled the lever, but the grey door under it did NOT open.  The grey door on the far right did however.
15509
The vine in the middle is not close enough for Jack to make the jump UNLESS he steps to the very edge to jump.  He will not know to do this until he looses a couple of lives.  Not Good.
15310
In NORMAL version, on the roof, near the pole a fast brick catches Jack and fast tracks him to this room, giving him a chance to get off OR sweep him back to the pole.
In this HARD version, the yellow brick, grabs Jack at the pole and stays in this room.  Forcing Jack to do this entire section again, just to get down the pole.  Is this on purpose, or an error?
HARD VERSION
16913
The hidden ladder that leads to the room below is defective.  Jack falls to his death.  Can't go down there to p/u monies, but I think that the secret will count as he fell to his death in the below room.
16113
This area is still a bit off.  If Jack jumps into the zapper space, then out he ends up on the bat mobiel which immediately takes him up to the next level.  He now can't get back down to the 1st bat level, to go to the right room to pull the lever.   see pic He has to wait until he finished the entire top to do this. I guess that is ok, but I panicked because I thought that the lever was for the zappers. A new player will think the same. hmmm? what to do, what to do?
15114
The 1st spider in this room is a cheap death.  That spider is lower than the one next to him.  It catches Jack without warning on the batmobiel.
15113
see roof top pic, it hasn't got a room number because I took the pic from the MLB & used test room in there as I could not get up to the roof in the game.  Notice, if Jack continues to walk (without jumping to the steps 1st) to the black brick, there is NO DROPPING BRICK, JUST A HOLE, WHICH HE FALLS THRU.
But, if he jumps onto the steps, and goes down to the black brick, there is a dropping brick there to catch him.  hmmmm?
HARD VERSION
16515
Pls check the vines in the tree in this section.  They are very stuttery.  Especially jumping from the ladder to the left ledge, Jack fell to his death.
16114
This room has 2 blue doors & I have 1 blue key & 1 green & 1 purple key left.  Is the 2nd blue key in the lowest section where Jack could not get down the ladder?
pls see pic of key & door count & also the map showing that I opened all the doors & should NOT have a green & purple key left over.  Your door & key count seem to not coincide with one another.  see pic.
I will add a blue key in the MLB so as to continue testing.
HARD VERSION
16317
The 1st vine Jack has to jump on is very stuttery.
16517
If Jack pulls the lever before he p/u the money BAG, the red platform does not reset itself if he leaves the room, so he can't get the money bag.  This one platform should reset itself closed so the he can get the money.
15916
I had the same problem in Normal version.  2 purple doors only 1 purple key.  Is this intentional or just a miss-count.  Most players like to open ALL the doors, me included!
16119
There is a real weird layer problem at the middle of the ladder.  All works well if Jack goes straight up and down.  When he jumped from the middle level to the right to get the coins & then back left, to the ladder so that he can go down, he landed at just the edge of the ledge & could NOT go down or up the ladder.  But if he jumps past the outer edge into the actual center of the ladder, then he can go down or up. hmmm.  see pic
16120
Can't get the 2 gold coins at the top of the tree.  Maybe a vine would help?
HARD VERSION
16520
The clues in the sign (see pic) are very misleading.  Most people do NOT know the colour sequence of the rainbow nor Snooker.  So your clue gives the impression that the 2nd brick is the brick of choice, as it was in the Normal Version, but in this case, after many deaths, it's the blue brick, which is the 4th brick. Unless you want to count a grey colour into the rainbow, which is the 5th you are referring to in your clue.  hmmm.
16522
Man are there ever a lot of red doors and me with only 5 red keys!!!  Where the heck were the rest of the red keys???
Can someone else pls test this mansion.  As I cannot figure this out.  Thank you.
16518
BRILLIANT ROOM!!!  OVERWHELMING AT 1ST GLANCE.  IT WAS A WTF MOMENT.........GENIUS, PURE GENIUS!
OK, FINISHED WITH 90% FOUND SECRETS.  MUCH BETTER THAN IN NORMAL, WERE I ONLY FOUND 75%.  BUT IN THIS CASE I USED THE MLB MOST OF THE TIME TO FIND YOUR SNEAKY TACTICS.  LOLOLOL
Re: Beta 4: Citadel of Dr. Cassiopus - Toybox - 07-03-2010
OK, will look into all these things tomorrow :o (But I still won't announce how many keys one should find at most Tongue I'll see if I rephrase this).
About that last riddle, I have been looking for a proper question for a long, long time and never really came up with something satisfying. So if you have better suggestions for riddles I'd be happy to use this.
Probably I was hoping to motivate the player to learn about snooker Wink The colour sequence in a rainbow are sort of useful actually (they may pop up in trivia games every now and then).
Re: Beta 4: Citadel of Dr. Cassiopus - Toybox - 07-04-2010
333A2C3A32325B0 wrote: 16505 - Normal
I have tried everything to get to the ladder that leads to the bottom level, but Jack is stuck & can't continue with the game.
Both levers in this room move the same brick, but the brick does NOT go down.  It just stays up in the air.
Even if Jack tries room 16707, he cannot continue because the bat brick has to be freed by the lever on the top left, which he can't get to because the lower left grey door is blocking him.  This whole area is very weird.  Pls check it out.  Maybe it's just me, or there really is a problem in room 16505 area, preventing Jack from going down.
NOTE: Okay, I finally figured out the problem.  My Jack entered room 16505 1st via the ladder on the left & pulled the lever which made the brick come out above his head.  But he still could not get down, so he had to go up & out to re-enter this same room using the bat bricks on the right.
The brick that was pulled out of it's place, was back in it's place when Jack re-entered this room via the bat bricks.  So he pulled the other lever in the middle of the room which sent the brick back out to where it went with the 1st lever. hmmmm.  THIS SECTION IS SO NOT RIGHT.  THE BRICK SHOULD HAVE STAYED OUT WITH THE 1ST LEVER, THEN LOWERED WITH THE 2ND LEVER AND STAYED THAT WAY, SO THAT THE PLAYER KNOWS TO RE-ENTER THIS ROOM FOR THE 3RD TIME.
Anyway, Jack finally, on the 3rd re-entry of this room, pulls the lever near the ladder, this time it allows Jack to pull it for the 2nd time and the brick comes back out over his head, as before, only this time it finally goes down as well.
Either I am having a glitch in my game, or this is a very confusing play.  Pls check it out.
Fixed.
40495F494141280 wrote: 16313 - Normal
Layer problem.  see pic, Jack is standing in mid-air.
No idea what was causing this bug. Anyway, fixed.
