Mansion Comments: The caves and the castle - Printable Version
+--- Thread: Mansion Comments: The caves and the castle (/showthread.php?tid=1317)
Re: Mansion Comments: The caves and the castle - brell - 04-12-2010
373E283E36365F0 wrote: EASY
11079
I think that there is NO WAY for Jack to get down from the upper ledge with the BB sign.  He has a blue key to use on the lower door & can't get down, so he used it on the 3rd upper level room & now he is missing a red key to proceed & can't.  hmmm  Maybe the red key was behind the blue door he could not get to on the lower level????
Thank you Missy. It is surely easy to miss this. Fixed.
Re: Mansion Comments: The caves and the castle - brell - 04-13-2010
0D3B333773103F2A37283B5E0 wrote: 10479 Normal
Cheap death: tall column is not solid. Jack dies if he tries to jump on it.
586E666226456A7F627D6E0B0 wrote: 11678 Normal
Jack jumped on blue bat platform when it got to the top, and then went to get all the stuff in the middle. Well, the blue platform had gone back down and Jack was stuck.
Both fixed, I think
4B505D4A4A4154090101380 wrote: BB's  - First room -
Instead of 'try not to dazzle
I think you mean not to stay there very long (dazzle means to be a flashy show-off) so it should be 'try not to dawdle
(means to leave quickly). Also, the last line
who like to eat the braves
doesn't make sense. Do you mean the trolls like to eat the brave adventurers or like to eat the adventuresome or like to eat courageous explorers?
I will be happy to help you with the phrases.
Sherry
Thank you Sherryl. I'd surely like to learn more of your language. Would this work with first rhyme:
Behind the mountains lies a castle.
Try to reach it without a hazzle.
You need to find your way through caves
of trolls who like to eat the knaves.
42747C783C5F7065786774110 wrote: 11679 Normal
Jack used a red key in 11679 and maybe should have used it in 11879? It seems that if you don't use the red keys in the right order, Jack can get stuck.  See map pic for where he's been.
Jack can't jump up onto the moving gold brick to get the yellow key (in 11679) and so has nowhere to go.
Yes, I 'KNEW' that someone would find a way to get stuck on this one although I thought I had tried everything  Wink
It should NOT matter which red door you open first.
Fixed (I hope  :Smile )
Re: Mansion Comments: The caves and the castle - Semi-Native - 04-13-2010
29392E27274B0 wrote: Thank you Sherryl.  I'd surely like to learn more of your language.  Would this work with first rhyme:
Spell it
hassle
not
hazzle
4454434A4A260 wrote: [quote author=42747C783C5F7065786774110 link=1270280869/4#4 date=1270991861]11679 Normal
But ... but ... !?
What did you do in room 11278?  How come you can't open the red door in 11279? You do NOT need a red key from the lower rooms to continue.
31070F0B4F2C03160B1407620 wrote: [quote author=29392E27274B0 link=1270280869/12#12 date=1271189122]Thank you Sherryl.  I'd surely like to learn more of your language.  Would this work with first rhyme:
Spell it
hassle
not
hazzle
Thanks ;-)
5545525B5B370 wrote: [quote author=4454434A4A260 link=1270280869/13#13 date=1271189520]But ... but ... !?
Ah, I didn't find the red key in 11278. I didn't discover that secret until I played again. So maybe there is no problem after all.
:Smile
