GraphicConverter - Printable Version
+--- Forum: Custom Mansions / Art (https://actionsoft.com/forum/forumdisplay.php?fid=26)
+--- Thread: GraphicConverter (/showthread.php?tid=1110)
GraphicConverter - josephine - 05-14-2009
Hi all- does anybody have experience using GraphicConverter? I can use it to access and modify graphics in the MM Sprites file (like changing a brick color.) But the saved changes don't show up in resource file. GC also lets me add/replace graphics to the file but those don't show up in the mansion builder either. Any ideas?
(Forgive my naive questions, I've read all the readme's and joeb's excellent tutorial but I'm still not sure if I need a resource editor with GC.)
Thanks!
Re: GraphicConverter - aquaMat - 05-14-2009
Hi Josephine,
I have no experience using
Graphic Converter
(even though I have the software, I have never used it), however I do use other applications to change sprites or tiles in MM.
First of all you should use a Resource editor, I feel that
Rezilla
works best (as far as MM goes), but even Rezilla has its fair share of bugs.....
Usually I first open the resource file of the tile / brick / sprite etc. I want to change, using/opening the files
Midnight Mansion Graphics
or
Midnight Mansion Sprites
in Rezilla.
Then I open the image of said resource - say a blue floor switch - (within Rezilla) and copy the image into Photoshop (for example).
There I can change the image to my taste and maybe save it under a new name. When I'm finished I copy the (changed) pic again.
Back in Rezilla I open the file ________ (your mansion name), and once it is opened I
Create a new Res
, make it a
PICT
resource and give it the same res ID (number) as the original tile / sprite I have changed (in our case: the orig. blue floor switch). An empty resource field opens.....with cmd-V I paste my (copied) new picture into the field, hit save and close it.
Voilà:  Within my custom-mansion's resource now resides a new custom graphic
PICT
res file which afterwards automatically shows up in the Mansion Level Editor, and - ultimately - within the game, whenever I play the new custom mansion.
I hope that helps ?
Re: GraphicConverter - josephine - 05-16-2009
Thanks aquamat!
I was hoping to just use Graphic Converter since I'm only making simple changes, like colors not ID's. It looks like I will have to learn ResEdit Tongue
Oh well, Graphic Converter is ok (and free) but not nearly as good as Photoshop.
Re: GraphicConverter - otg - 05-16-2009
Perhaps the mistake is to change the image in the Sprites file and not in the [as aquamat points out] mansion file?
Re: GraphicConverter - josephine - 05-17-2009
Thanks Olle. (I'm not exactly sure how I did this but...) with a combination of GC, ResEdit/Classic and Photoshop my new brick appeared in the mansion builder and the custom mansion.
Once.
After making another change to the new brick and reimporting it, it disappeared >Sad
Anyway, now that I have a better idea of the steps, I'm going to start over with all new files. Wish me luck!
Re: GraphicConverter - SandyBean - 05-18-2009
Hi Josephine,
I'm going to wish you luck too, cause whatever you three are talking about, it sounds like Greek to me!!!  (And I have built one mansion, and have one half finished for the new, improved mansion builder when the Expanded MM is released), and still have not got a clue of the advanced stuff and other programs you guys are talking about and using with obvious ease!
My Kudos to you guys for being so inventive and resourceful !!!  [smiley=vrolijk_1.gif]
Thanks for sharing your mansions made with all you guys' hard work with our MM world !
SandyBean [smiley=2vrolijk_08.gif]
Re: GraphicConverter - brell - 05-18-2009
Josephine, are you doind the changes in the classic environment? Perhaps it is causing a problem? You could try Rezilla instead of ResEdit.
Re: GraphicConverter - aquaMat - 05-18-2009
I would guess so too.
As I said above, I feel that Rezilla works better for MM than ResEdit anyway.... and I didn't even take the
Classic issue
into account.
But considering this you're almost beggin' for troubles!   Wink
As far as PICT resources go....the good thing about Rezilla is that
what you see is what you get
But beware: after having changed a PICT res and copied it into a Rezilla res ID window you should hit SAVE immediately and once more after closing the ID window....and then it still happens sometimes that the new PICT has disappeared when you reopen the same PICT res window.
This is one of the major bugs in Rezilla, that I mentioned above.
So after including several new PICT resources you should always re-check ALL of them at least once to make sure they are still there !
Re: GraphicConverter - josephine - 05-19-2009
Thanks guys. I've been making the graphics changes in OSX but using ResEdit in Classic mode to make a new resource and ID's (mostly because ResEdit was already on my computer.) I downloaded Rezilla, will give it a try.
SandyBean- Immortal Ruins was good, you should do another mansion (nudge nudge Wink ;D ) Smooch the horses for me!
Re: GraphicConverter - josephine - 05-21-2009
OK, Rezilla seems to work when modifying a brick (say, changing the original blue brick to dark blue.) And like you said aquaMat, sometimes the
saved
PICTs disappear. But I'm not having any luck adding a new brick. The new brick appears in the MM Sprites file when I open it in Rezilla but not in the mansion builder (like the resource map isn't seeing it or something. I have only a vague understanding of forks and stuff. Can you tell I'm not a programmer? Big Grin )
This is what I did:
Open MM Sprites file in Rezilla> copy blue brick> quit> open Photoshop> new file, paste, change brick to dark blue> save, copy, quit> open MM Sprites in Rezilla> new resource> type PICT and give it an ID that's not already taken (in this case 202)> new window opens, paste dark blue brick> SAVE> save again just for fun> close window> save and quit. Open MM Sprites in Rezilla again, new brick is there, quit. Open mansion builder but there's no new brick.
It's probably not a big deal, as long as my custom mansion doesn't need lots of different bricks. But I hate being limited Wink
